Hi list,
I'm trying to create a shadow map of buildings.
Well, I have a vector buildings map that I rasterized with Z values. This
worked ok.
I, then, generated slope map and aspect map -which contains only null
values, but that's ok.
I'm trying now to generate a shadow map but I'm not able to. I did 2 things
1 - first, I tried the following script
/www.grassbook.org/scripts2nd/rsun_crop.sh.txt. It generates files but I get
nothing when displaying them and for now I don't want all these values but
just want to understand better how it works.
2 - I want then to run that simple command line :
r.sun -s elevin=bati_rast aspin=bati_aspect slopein=bati_slope day=82
time=16 glob_rad=bati_grad
but I'm still not able to display anything on my monitor (no irradiation nor
shadow).
For information, I use grass v 6.4.0+42329 and my raster is supposed to be
projected in Lambert 93 :
*g.region -p* gives me the following result :
/projection: 99 (Lambert Conformal Conic)
zone: 0
datum: towgs84=0,0,0,0,0,0,0
ellipsoid: grs80
north: 769395.43918527
south: 768108.47249135
west: 401488.30985985
east: 403400.72187053
nsres: 0.99997412
ewres: 1.00021549
rows: 1287
cols: 1912
cells: 2460744
Do the /-s option/ work in both modes? In that case, what is returned when
no local time is given or when working in mode 2?
Help would be very appreciated!
Many thanks,
simo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/R-sun-use-tp6520934p6520934.html
