Dear List,
I am trying to create a hillshade map with shadowing effect of the topography. It seems r.sunmask should be my weapon of choice, but it is incredibly slow. Then I found a mail to the userlist in 2007 where Markus replies on this issue(http://osgeo-org.1560.n6.nabble.com/long-run-time-with-r-sunmask-td3936587.html) saying that extracting NULL values of the incidence angle map in r.sun would be an alternative.
Is this still the better way or are there alternatives nowadays? I might miss something as the tool is quite complex in its options and am not aware of how to use the r.horizon approach, but running r.sun in simple mode -using elevation, aspect and slope as input- is still slow and produces a gradient across the map. Am not sure if this is the correct output.
Command:
r.sun -s elevin=r_dem incidout=r_sun_shadow aspin=r_aspect slopein=r_slope day=80 time=17 --o
Thank you for any help.
patrick
