Is r.surf.nnbathy compatible with GRASS 7.0? It doesn’t seem to be listed on the GRASS7 Raster AddOns page. And, the install instructions that I have found all refer to GRASS 6.
I have the nnbathy binary from 6 working fine. Can I just copy over the script and binary? Is there a new version?
Is r.surf.nnbathy compatible with GRASS 7.0? It doesn't seem to
I don't think there is a newer version, but there's
a good chance that the GRASS 6 one still works. Give
it a try and let us know!
In general cloned code is to be avoided, and svn
supports symlinking, so a possible solution for
known working addons (scripts) is to symlink in
the parent directory. Hopefully the build system
is not too grumpy about mixed python and shell
scripts. If it is we should come up with a solution
to fix that.
I don’t think there is a newer version, but there’s
to fix that.
Adam:
Thanks. It is working.
Hamish:
to fix that.
I've just added a new r.surf.nnbathy dir in the grass7/raster addons, with symlinks back to the grass6 dir. I had to do each file individually instead of jus the dir since description.html needs to be renamed to [g.module].html. Svn stores it as a "link" file internally, and I believe a checkout on Windows will make a full copy of the files since there are no symlinks there.
if it works it will be a nice temporary solution to avoid the extra maintenance overhead and divergence.
