[GRASS-user] r.terraflow error for ASTER DEM.
Dear all,
I tryed to run the following over a ASTER GDEM elevation map:
r.terraflow elevation=ASTGTM_S25W049_dem filled=ASTGTM_S25W049_dem_terraflow_filled direction=ASTGTM_S25W049_dem_terraflow_direction swatershed=ASTGTM_S25W049_dem_terraflow_swatershed accumulation=ASTGTM_S25W049_dem_terraflow_accumulation tci=ASTGTM_S25W049_dem_terraflow_tci
But I got the following errors (which suggest me to contact support team :slight_smile:
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
raster FabioASTGTM_S25W049_dem is of type CELL_TYPE --you should use r.terraflow.short
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
file stats.out exists - renaming.
ami_single_temp_name: mkstemp failed: : No such file or directory
Assertion failed: 0, file ami_stream.cc, line 75
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
By the way, I am running grass 64R4 under Vista 64 bits.
Bests
milton
brazil=toronto
On Sun, Jul 5, 2009 at 8:07 AM, Milton Cezar
Ribeiro<miltinho.astronauta@gmail.com> wrote:
Dear all,
MFD flow direction
r.terraflow.short
way.
Please contact the application's support team for more information.
I found this in the archive:
On Fri, Nov 7, 2008 at 2:14 AM, Glynn Clements<glynn@gclements.plus.com> wrote:
Helena Mitasova wrote:
has anybody tried to run r.terraflow in winGRASS?
It cannot find or create the temp file?
ami_single_temp_name: mkstemp failed : No such file or directory
assertion failed: 0 file ami_stream.cc line 54
is it trying to write into /var/tmp which does not exist in windows?
1. The error message is inaccurate; it doesn't actually call mkstemp()
on Windows, but mktemp().
2. The directory used for temporary files is controlled by the
STREAM_DIR= option (renamed to stream_dir= in 7.0). /var/tmp is just
the default setting.
3. The default value of /var/tmp is inappropriate for Windows. It
should probably use the TMP or TEMP environment variables. There
probably won't be a specific directory which will be writable by all
users.
grass-windows mailing list
Would be good to get that fixed for 6.4.0.
way.
Glynn:
I have submitted a patch, now the error is reported correctly
on Windows.
Glynn:
@Milton: please try this parameter to define a different directory.
Glynn:
users.
Ok, but the current default fails for sure. Personally I still think that
the current mapset is a more appropriate default.
We should change on Windows at least to a "more likely" directory.
Which?
>> users.
Which?
  G_convert_dirseps_from_host(G_store(getenv("TEMP")));
On Sun, Jul 5, 2009 at 3:35 PM, Glynn Clements<glynn@gclements.plus.com> wrote:
>> users.
Which?
   G\_convert\_dirseps\_from\_host\(G\_store\(getenv\(&quot;TEMP&quot;\)\)\);
done in
6.4.0svn: http://trac.osgeo.org/grass/changeset/38256
6.5.svn: http://trac.osgeo.org/grass/changeset/38254
7.svn: http://trac.osgeo.org/grass/changeset/38253
          http://trac.osgeo.org/grass/changeset/38255
Windows testing welcome.
Glynn:
  1. The directory used for temporary files is controlled by the
Hi Markys, Glynn
Just to you know, I tryed to set the STREAM_DIR=C:\Data\0temp\0rterraflow
and get the same(?) error, see below:
stats.out: File exists
WARNING: raster FabioASTGTM_S25W049_dem is of type CELL_TYPE --you should
GRASS 6.4.0RC4 (newLocation):c:/Users/famiglia >
I will try to compile the fixed version and report it to you.
Cheers, milton
On Sun, Jul 5, 2009 at 5:33 PM, Milton Cezar
Glynn:
Hi Markys, Glynn
Just to you know, I tryed to set the STREAM_DIR=C:\\Data\\0temp\\0rterraflow
did you recompile?
/var/tmp/flowStream
was hardcoded, I have fixed that earlier today. So recompilation is
unavoidable for windows.
