[GRASS-user] r.terraflow usage (segfault)
Hi
i'm tring to use "r.terraflow"
following the help page i see :
r.terraflow elev=spearfish filled=spearfish-filled \
     dir=spearfish-mfdir swatershed=spearfish-watershed \
     accumulation=spearfish-accu tci=spearfish-tci
but i can't find any "spearfish" elevation data in the spearfish dataset
so i used elevation.dem insted, but i've a segfault :-/
i tried with different locatiuon too, using:
as data input an elevetion model (230m resolution)
in a wgs84 UTM 33 N location
but i have segfault again....
mybe my knowledge of the r.terraflow application is not so good, and i'm missing something to prepare the input data ?
i tried the same step having the same results
on a grass64 svn builded from source on different platforms
(ubuntu 8.04 32 bit , osx 10.5)
thanks for any help!
regards,
Massimo Di Stefano.
Chiacchiera con i tuoi amici in tempo reale! http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
On Thu, Nov 13, 2008 at 7:23 PM, Massimo Di Stefano
<massimodisasha@yahoo.it> wrote:
Hi
I have fixed the nonsense example to
r.terraflow elev=elevation.10m filled=elevation10m.filled \
    dir=elevation10m.mfdir swatershed=elevation10m.watershed \
    accumulation=elevation10m.accu tci=elevation10m.tci
Me, too.
This hack seems to cure the problem:
Index: main.cc
--- main.cc (revision 34205)
+++ main.cc (working copy)
@@ -211,7 +211,13 @@
   struct Cell_head cell_hd;
   if (G_get_cellhd (cellname, mapset, &cell_hd) < 0)
     G_fatal_error(_("Cannot read header of [%s]"), cellname);
+ /* get the current region and dimensions */
+ region = (struct Cell_head*)malloc(sizeof(struct Cell_head));
+ assert(region);
+ if (G_get_set_window(region) == -1) {
+ G_fatal_error("r.terraflow: error getting current region");
   /* check compatibility with module region */
   if (!((region->ew_res == cell_hd.ew_res)
                && (region->ns_res == cell_hd.ns_res))) {
but I dunno much about C++.
> Hi
Me, too.
This was introduced by r34198, which was back-ported in r34205.
region is being allocated, but not until after that point.
Fixed in r34285.
On Fri, Nov 14, 2008 at 1:36 PM, Glynn Clements
> Hi
Me, too.
Fixed in r34285.
backported to 6.4.svn.
