[GRASS-user] r.terraflow
Hi list.
I'm trying to use terraflow for the very first time, because
r.watershed is too much time consuming for my dataset. I've updated it
to include the recent patches to categories coding.
In the new coding scheme, when using the sdf option, 9 directions are
depicted (0,1,2,4,8,16,32,64,128). I reclassify them to compare the
result with r.watershed, but I'm not sure about the 0 values returned
by r.terraflow. In r.watershed the positive values, multiplied for 45,
give the direction angle relative to north, so 8 directions are used
(1-8), and I've setup the following reclassifying rules:
1=2
2=3
4=4
8=5
16=6
32=7
64=8
128=1
I miss the zeroes... I've given a rapid look to the source code, and I
see it's used as "default" return value. ???
Giovanni
G. Allegri wrote:
Hi list.
1=2
2=3
4=4
8=5
16=6
32=7
64=8
128=1
Hi Giovanni,
me and Ivan played some time ago with r.terraflow..you can find more info in
this topic:
http://www.nabble.com/r.watershed-and-swap-memory-to16116939.html#a16137454
Bye
Luca
View this message in context: http://www.nabble.com/r.terraflow-tp18691496p18697525.html
Thanks Luca.
The coding mapping seems correct. So, zeroes are for unsolved pixels...
I'll do some tests to compare the results with r.watershed. At now
they seem quite different. I'm not sure if I should trust onflow
directions from r.terraflow to use them in r.water.outlet...
2008/7/28 doktoreas <thedoktor78@gmail.com>:
G. Allegri wrote:
Hi list.
1=2
2=3
4=4
8=5
16=6
32=7
64=8
128=1
Hi Giovanni,
this topic:
Bye
Luca
grass-user mailing list
grass-user@lists.osgeo.org
Il giorno mar, 29/07/2008 alle 02.22 +0200, G. Allegri ha scritto:
Thanks Luca.
hmmmm.... in my opinion the r.terraflow output is not usefull for
r.water.outlet but if you find a solution please let we know :wink:
bye
Ivan
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
Ivan et al,
Below are some snippets from an email thread in 2005:
Has anyone had any luck using the results from r.terraflow in r.water.outlet? More specifically I want to use the output direction grid from r.terraflow for the drainage direction map input of r.water.outlet. The r.water.outlet documentation only refers to using a drainage direction map generated in r.watershed.
I really don't know about r.water.outlet but while r.whatershed generate
flow direction with a D4 or D8 algorithm while r.terraflow use a Dinf
algorithm (6 month ago the -s flag was not working, maybe now is fixed,
maybe not.... try to test....).
r.terraflow uses by default a MFD algorithm (multiple flow path). In short, the outflow of one cell is distributed among ALL its downslope neighbors, according to the relative differences in elevation. The nb stored in the flow direction output of terraflow corresponds to the neighbors id, stored as an octet (so, between 0 and 255), clockwise from East (1 for East, 2 for SE, 4 for S, 8 for SW...) : for example, if water flows to the North and the south simultaneously, the flow direction value is 68 (4 for S + 64 for N). NNE ? 64+128, and so on...
r.watershed uses a SFD (single flow direction) algorithm, where water is routed to ONE downslope neighbor. The flow directions are coded as an integer between 1 and 8.
There should be a trick to get main flow directions (pseudoSF) from terraflow MFD: check the sources, direction.cc: there's a series of test to get the main direction from the 0-255 value (function findDominant). A simple script should do the work. I tried to write such a script smoe time ago, but don't ask me where it is, my box is a mess these days...
OK, that makes sense. If I use the -s flag to force r.terraflow to use SFD will my flow directions be 1-8 rather than 0-255?
Nope, the values will still be between 0 and 128, but as 1,2,4,8,16,32,64,128 only: you'll still have to postprocess your data to get it to a number between 1 and 8. And make sure that the way the directions are reported in r.watershed are consistent (viz, 1 is E and you go clockwise)
I did try r.terraflow initially but in this case r.fill.dir is much faster because all I need is flow direction, not flow accumulation, TCI or any of the other things r.terraflow provides. Also, I was never able to figure out how to get the flow direction r.water.outlet needs from the r.terraflow flow direction (I was the guy that started that thread you mentioned). Regardless of what I use to get flow direction it would be helpful to know what format r.water.outlet expects, ie what direction is 1 North, East or something else.
for the record, here's some aspect map format information collected from
the help pages and source code:
(use d.rast.arrow and d.rast.num to investigate AGNPS, ANSWERS, GRASS
formats)
AGNPS (r.fill.dir)
category values from 1-8, with 1 facing north and increasing values in
the clockwise direction.
ANSWERS (r.fill.dir)
category values from 0-360 degrees, with 0 (360) facing east and values
increasing in the counter clockwise direction at 45 degree increments.
GRASS (r.fill.dir)
broken in 6.0.0. (was old GRASS 4? format) In the old days (pre-floating
point GRASS rasters) there was a 24-points based GRASS aspect map format
which still rears its ugly head sometimes:
24,1,2 east
3,4,5 north east
6,7,8 north
9,10,11 north west
12,13,14 west
15,16,17 south west
18,19,20 south
21,22,23 south east
GRASS (r.slope.aspect, others)
categories represent the number degrees of east and they increase
counterclockwise: 90deg is North, 180 is West, 270 is South and 360 is
East. Beware: 0 may be null! Similar to the ANSWERS format AFAICT.
r.param.scale
the direction of maximum gradient (considered downslope) is stored as
(West is 0 degree, East is ± 180 degree):
* 0..+180 degree from West to North to East
* 0..-180 degree from West to South to East
[Anomaly: I vote for changing this to standard GRASS5 aspect format]
r.watershed drainage map (what r.water.outlet wants)
drainage direction. Provides the "aspect" for each cell. Multiplying
positive values by 45 will give the direction in degrees that the
surface runoff will travel from that cell. The value -1 indicates that
the cell is a depression area (defined by the depression input map).
Other negative values indicate that surface runoff is leaving the
boundaries of the current geographic region. The absolute value of these
negative cells indicates the direction of flow.
[should we change this to standard AGNPS(+neg flag) aspect format ??]
It would be nice to get these down to AGNPS, ANSWERS, and GRASS format
anyway.
so AGNPS is not the same as r.watershed format, but 45deg off:
dir AGNPS r.watershed
N 1 0 or 8 ?
NE 2 1
E 3 2
SE 4 3
S 5 4
SW 6 5
W 7 6
NW 8 7
fix:
r.mapcalc 'aspect.watershed = if(aspect.AGNPS == 1, 8, \
  if(aspect.AGNPS > 1 && aspect.AGNPS <= 8, aspect.AGNPS-1, null() ))'
if that works we can add it to the help page. (looks ok to me)
note the negative values from the watershed program will be lost, which might adversely affect the output of r.water.outlet! (no idea)
FYI, I've whipped up a Matlab script to extract the dominant flow direction from the r.terraflow MFD output map and reclass it into
the GRASS aspect format for use with d.rast.arrow, etc. It should
be easy enough to rewrite it in something more Free and convert the
export into any of the above aspect formats by changing asp_mtx.
Usually you can just use r.slope.aspect directly as a proxy.
find it here:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
AFAICT: 1 is NE, moving around the compass clockwise until 8 is North,
and mind the negative values and information lost by taking the absolute
value of flow direction.
Drainage direction needed by r.water.outlet:
N: this means that water is going to North ...
N: 2
N/E: 1
E: 8
S/E: 7
S: 6
S/W: 5
W: 4
N/W: 3
I hope this helps…
Tom
Thanks Luca.
bye
Ivan
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
Thanks Thomas. I think we should put these on the wiki... When I find time.
I understand the coding scheme, but reclassifying from directions
r.terraflow scheme to the r.watershed one yealds significative
differences, and r.water.outlut works bad with the r.terraflow
results... The main problem is that r.terraflow produces lots of
zeroes, where r.watershed resolve the directions.
I think I will go on with r.watershed, but having to tile the whole
raster, I have to solve the problem of patching the tiles (because my
basins cover areas bigger then what my machine can manage in one
shot). The patches produce artifacts along the boundaries.
I will let you know if I find solutions.
2008/7/29 Thomas Adams <Thomas.Adams@noaa.gov>:
Ivan et al,
clockwise)
else.
formats)
AGNPS (r.fill.dir)
GRASS (r.fill.dir)
24,1,2 east
3,4,5 north east
6,7,8 north
9,10,11 north west
12,13,14 west
15,16,17 south west
18,19,20 south
21,22,23 south east
r.param.scale
anyway.
N 1 0 or 8 ?
NE 2 1
E 3 2
SE 4 3
S 5 4
SW 6 5
W 7 6
NW 8 7
fix:
find it here:
N: 2
N/E: 1
E: 8
S/E: 7
S: 6
S/W: 5
W: 4
N/W: 3
I hope this helps…
Tom
Thanks Luca.
bye
Ivan
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
