[GRASS-user] r.texture error
I'm running r.texture over an image but I get the following error:
Reading raster map...
ERROR: Too many categories (found: 300, max: 255). Try to rescale or
reclassify the map
What is mean?!!??What are the categories?How can I reduce that?
No idea what this mean!!
Solimyr
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-texture-error-tp6807585p6807585.html
On Mon, Sep 19, 2011 at 10:22 AM, Solimyr <giannicristian@msn.com> wrote:
reclassify the map
Like this:
r.rescale input=input output=output to=0,255
r.texture ...
I have improved the manual now to better explain this issue.
Thanks for the answer!!!Can you link to me the manual url please?
I’m not understand why I must do that (rescale) because if I change the kernel window and the step I get different value from 300 (but all over 255).
If I do this rescale and I compare the result with the ENVI tool or the ArcMap tool, I get the same results or this rescale will change the result?
Thanks in advance for the answer!
Solimyr
Date: Mon, 19 Sep 2011 12:43:09 -0700
To: [hidden email]
Subject: Re: r.texture error
On Mon, Sep 19, 2011 at 10:22 AM, Solimyr <[hidden email]> wrote:
I’m running r.texture over an image but I get the following error:
Reading raster map…
reclassify the map
Like this:
r.texture …
grass-user mailing list
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/r-texture-error-tp6807585p6809826.html
To unsubscribe from r.texture error, click here.
View this message in context: RE: r.texture error
http://grass.osgeo.org/grass64/manuals/html64_user/r.texture.html
I'm not understand why I must do that (rescale) because if I change the
255).
The input map range must be between 0..255. To reach that, use
r.rescale:
http://grass.osgeo.org/grass64/manuals/html64_user/r.rescale.html
I suppose that the results are similar or even identical. Probably
ENVI or ArcMap also rescale internally (as GRASS 7 does) without
telling you...
