Hi all
The r.tile module don’t have overwrite flag, so if we re run the module with different parameters but with same output prefix name, then it will rewrite output with out warning.
Is this intentional?
Another point is, if I use overlap option it adds double the overlap cells to the output maps.
For example in the NC location:
r.info elevation -g
rows=1350
cols=1500
r.tile input=elevation output=elev_tile width=750 height=675
r.info elev_tile-001-001 -g
rows=675
cols=750
r.tile input=elevation output=elev_tile width=750 height=675 overlap=50
rows=775 (+ 100)
cols=850 (+ 100)
In the last case the rows and cols should be 725 and 800 respectively, as it should add 50 cells as overlap to each tile? Or am I missing something?
Regards
Sajid
Hi Sajid,
I have never used r.tile before, but checking the code [1], it multiplies the overlap by 2, so there’s why. Now guesstimating, if I set an overlap of 50, I would expect to have that overlap on both sides of the desired size of the tiles, so maybe that’s why it is doubled ?
HTH,
Vero
[1] https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.tile/main.c#L101
El mié., 7 nov. 2018 a las 15:08, Sajid Pareeth (<spareeth@gmail.com>) escribió:
Hi all
r.info elevation -g
rows=1350
cols=1500
rows=675
cols=750
rows=775 (+ 100)
cols=850 (+ 100)
Regards
Sajid
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Nov 7, 2018 at 7:06 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Hi Sajid,
In princliple that’s correct, but not for the first and last row and column of tiles.
In Sajid’s example, the first and last row of tiles should have 725 rows (675 + 50) and all other tiles 775 rows (675 + 2 * 50). Accordingly for columns.
That should be relatively easy to fix.
Markus M
HTH,
Vero
Hi all
r.info elevation -g
rows=1350
cols=1500
rows=675
cols=750
rows=775 (+ 100)
cols=850 (+ 100)
Regards
Sajid
Thank you both,
I got confused between first and last row tiles and the middle ones.
The overlap is fine on first and last row tiles.
Regards
Sajid
On Wed, Nov 7, 2018 at 7:37 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hi Sajid,
Markus M
HTH,
Vero
Hi all
r.info elevation -g
rows=1350
cols=1500
rows=675
cols=750
rows=775 (+ 100)
cols=850 (+ 100)
Regards
Sajid
On Wed, Nov 7, 2018 at 9:17 PM Sajid Pareeth <spareeth@gmail.com> wrote:
Thank you both,
The produced tiles are correct. What might be confusing is that in case of overlap the tiles at the edges of the input map extend beyond the input map, with their parts beyond the extents of the input map filled with NULL values. This could be improved by special treatment of the tiles at the edges of the input map. It could also be a bug for global maps where the resulting tiles at the northern edge go above 90 degrees North and the resulting tiles at the southern edge go below 90 degrees South.
Markus M
Regards
Sajid
Hi Sajid,
Markus M
HTH,
Vero
Hi all
r.info elevation -g
rows=1350
cols=1500
rows=675
cols=750
rows=775 (+ 100)
cols=850 (+ 100)
Regards
Sajid
