I'm facing problems with r.to.vect.lines addon module on different platforms (Fedora 23, Windows 10).
I compiled GRASS GIS 7 from svn source (updated right now to GRASS GIS 7.0.5svn R68347), see configuration at the end of the e-mail), then installed the addon using g.extension. Installing works fine, but when I run the command (either from GUI or command line) it provides me the following error:
File
"/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py",
line 263, in OnItemSelected
self.cmdDesc = gtask.parse_interface(cmd)
File
"/usr/local/grass-7.0.4svn/etc/python/grass/script/task.py",
line 520, in parse_interface
"<{name}> module: {error}").format(name=name, error=error))
grass.exceptions
ScriptError
Cannot parse interface description of<r.to.vect.lines>
module: not well-formed (invalid token): line 17, column 19
The last two lines also appear in grass shell when I launch GRASS 7.
I have no ideas about the origin of such error, any idea?
Thank you,
Carlo
Informazioni di sistema
Versione di GRASS: 7.0.5svn
Revisione SVN GRASS: 68347
Build Date: 2016-05-02
Build Platform: x86_64-pc-linux-gnu
GDAL/OGR: 2.0.2
PROJ.4: 4.9.1
GEOS: 3.4.2
SQLite: 3.11.0
Python: 2.7.11
wxPython: 3.0.2.0
Piattaforma: Linux-4.4.8-300.fc23.x86_64-x86_64-with-fedora-23-Twenty_Three
Hi Carlo,
I just tried on my F23 box, no issues there.
Idea:
On Mon, May 2, 2016 at 10:14 AM, Carlo Cormio <carlo.cormio@gmail.com> wrote:
error:
File
^^^^should be 7.0.5svn in your case
Be sure that you run "make distclean" , then compile.
best
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Hi Markus,
Il 02/mag/2016 10:10 PM, “Markus Neteler” <neteler@osgeo.org> ha scritto:
Hi Carlo,
Idea:
“/usr/local/grass-7.0.4svn/gui/wxpython/gui_core/prompt.py”,
Be sure that you run “make distclean” , then compile.
best
My fault in copy-paste action. I didn’t “make distclean” at first version update, and then copied the error message from grass his output. I saw from system setting there was something wrong (grass gis 7.0.4). Then I compiled everything in the right way (make distclean, svn up, compile blablabla, make, make install) and checked add-on (working or not) once again, but didn’t replaced the error message (that was the same as the posted one) in mail text, sorry.
Anyway, I will make a double check tomorrow morning and will let you know (hopefully good news). I will try uninstalling and reinstalling the add-on.
Thank you,
Carlo
Good morning everybody,
a few minutes ago I removed r.to.vect.lines (g.extension -f extension=r.to.vect.lines operation=remove) and reinstalled it again, but get the same error once again:
Il 02/05/2016 22:33, CARLO CORMIO ha scritto:
Hi Markus,
Hi Carlo,
Idea:
best
Thank you,
Carlo
File
"/usr/local/grass-7.0.5svn/gui/wxpython/gui_core/prompt.py",
File
"/usr/local/grass-7.0.5svn/etc/python/grass/script/task.py",
grass.exceptions
ScriptError
Mhh.. can you please try
r.to.vect.lines --interface-description
and check if it outputs XML?
HI Markus,
this is the result (xml):
GRASS 7.0.5svn (MonteMarioZona1_3003):~ > r.to.vect.lines --interface-description
<!DOCTYPE task SYSTEM "grass-interface.dtd">
<task name="r.to.vect.lines">
<description>
Convert raster rows to vector lines.
</description>
<keywords>
raster, conversion, wiggles
</keywords>
<parameter name="input" type="string" required="yes" multiple="no">
<description>
Nome della mappa raster di input
</description>
<keydesc>
<item order="1">name</item>
</keydesc>
<gisprompt age=""old" element="cell" prompt="raster";" />
</parameter>
<parameter name="output" type="string" required="yes" multiple="no">
<description>
Nome della mappa vettoriale di output
</description>
<keydesc>
</keydesc>
<gisprompt age=""new" element="vector" prompt="vector";" />
</parameter>
<parameter name="skip" type="integer" required="no" multiple="no">
<description>
Sample every Nth grid row
</description>
<default>
10
</default>
<values>
<value>
<name>1-100000</name>
</value>
</values>
</parameter>
<flag name="v">
<description>
Sample vertically (default is to sample horizontally)
</description>
</flag>
<flag name="help">
<description>
Print usage summary
</description>
</flag>
<flag name="verbose">
<description>
Output verboso del modulo
</description>
</flag>
<flag name="quiet">
<description>
Output quieto del modulo
</description>
</flag>
</task>
ALso XML Copy Editor analysis provides the same error message:
Error at line 17, column 26: not well-formed (invalid token)
It seems there's something wrong with gisprompt, but I'm unable to understand and fix, sorry.
Thank you,
Carlo
Il 06/05/2016 15:50, Carlo Cormio ha scritto:
HI Markus,
<description>
</description>
<keywords>
</keywords>
<description>
</description>
<keydesc>
</keydesc>
</parameter>
<description>
</description>
<keydesc>
</keydesc>
</parameter>
<description>
</description>
<default>
10
</default>
<values>
<value>
</value>
</values>
</parameter>
<flag name="v">
<description>
</description>
</flag>
<flag name="help">
<description>
Print usage summary
</description>
</flag>
<description>
</description>
</flag>
<flag name="quiet">
<description>
</description>
</flag>
</task>
2016-05-06 15:59 GMT+02:00 Carlo Cormio <carlo.cormio@gmail.com>:
it seems to be here:
the correct form is:
<gisprompt age="old" element="cell" prompt="raster" />
Unfortunately I don't have time to investigate where the bug could be. Martin
</value>
</values>
</parameter>
<flag name="v">
<description>
</description>
</flag>
<flag name="help">
<description>
Print usage summary
</description>
</flag>
<description>
</description>
</flag>
<flag name="quiet">
<description>
</description>
</flag>
</task>
grass-user mailing list
grass-user@lists.osgeo.org
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On 5/6/16, Martin Landa <landa.martin@gmail.com> wrote:
Fixed in r68382. Two wrong ";" chars removed (I suppose a leftover
from the related C syntax while this is Python).
Carlo, please try again.
MMMh, maybe I'm making a mess ...
I "make distclean" my GRASS GIS build, updated svn (svn up) to r68383, then compiled and make, but it says it's r68381.
Do I have to make something different to compile and install the righr revision?!
Carlo
On May 6, 2016 6:37 PM, “Carlo Cormio” <carlo.cormio@gmail.com> wrote:
MMMh, maybe I’m making a mess …
I “make distclean” my GRASS GIS build, updated svn (svn up) to r68383, then compiled and make, but it says it’s r68381.
Just g.extension r…
Carlo
<gisprompt age=““old” element=“cell” prompt=“raster”;” />
Fixed in r68382. Two wrong “;” chars removed (I suppose a leftover
Il 06/05/2016 18:55, Markus Neteler ha scritto:
Just g.extension r....
If so, I already tried before messing up everithing. The error appeared again.
GRASS GIS compiled and installed once again (svn up provided r68384), r.to.vect.lines removed and installed again, error appears again.
Ideas?
Thanks
Carlo
again.
Try g.extension again, I hopefully fixed it.
Anna
Ideas?
Thanks
Carlo
Hi Anna,
Anna
Interface appears now, but there's a new error message:
File
"/home/ccormio/.grass7/addons/scripts/r.to.vect.lines", line
191, in <module>
main()
File
96, in main
data_type = Rast_get_map_type(inmap, mapset)
NameError: global name 'Rast_get_map_type' is not defined
Carlo
On Sat, May 7, 2016 at 5:04 AM, Carlo Cormio <carlo.cormio@gmail.com> wrote:
Hi Anna,
Anna
File
191, in <module>
main()
File
96, in main
Carlo
Please, try again. The addon was apparently not ported to GRASS 7.
Anna
Works perfectly
Thank you very much Anna, Markus, Martin.
Carlo
Hi Anna,
Anna
File
191, in <module>
main()
File
96, in main
Carlo
Anna
