On 01/05/17 15:36, Vaclav Petras wrote:
On Mon, May 1, 2017 at 6:54 AM, Moritz Lennert
<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
On 01/05/17 12:43, Martin Landa wrote:
I need a tool which converts vector features (points) to raster map
using statistical method like min,max,mean (something like
`r.in.lidar` does - if more points are found within one cell, raster
value is computed by given method).
I started with module `r.to.vect`, but it takes only one attribute
value if more features found, `v.kernel` does not support
attributes.
There is probably such tool, I must overlook something...
I generally use v.to.db op=coor && v.db.select | r.in.xyz
<http://r.in.xyz> for such a task. I don't know if a dedicated
module would be much faster than a script that wraps around these
modules. I guess avoiding the v.to.db part could gain you some time
when dealing with lots of points.
Hi, this is certainly a missing feature. Even the v.to.rast
documentation [1] says:
v.out.ascii input=myschools_wake output=- column=value | r.in.xyz
<http://r.in.xyz> input=-
Duh, that's obviously much better than using v.to.db + v.db.select. I guess I haven't had many situations lately where the coordinates weren't already in the attribute table...
For certain cases, you may be able to use v.out.lidar instead of
v.out.ascii, but it is probably less efficient (although it uses LAS
instead of ASCII, you can't use pipes). You could also use v.mkgrid with
rectangular grid and v.vect.stats [2] followed by v.to.rast (which
avoids export, but for large grids it is likely very slow).
I have separated the binning code in r.in.lidar [3] so that it can be
used in r.in.xyz <http://r.in.xyz>
Is it different from the binning code in r.in.xyz ?
and the missing module which would do
the binning of a vector map into a raster map. There is actually a large
overlap with code for grid-based decimation of a point cloud (2D with
gridded or averaged X and Y). I already committed the code to r.in.lidar
[4], but we had a discussion on mailing list and decided that this
functionality should not be part of r.in.lidar, so it is disabled [5]
but the code is still there.
So what you are saying is that the code should go into a library and be used by all relevant modules ?
Anyway, a new module needs to be implemented for this. The name can be
something like r.binning, r.vect.stats, r.point.stats, or
r.points.stats. It might good project for beginners.
I like the idea. But do you really think this would be much faster than v.out.ascii | r.in.xyz ?
Moritz
