Here's the process I plan to do for my image classification
1. Create an unsupervised classification from TCAP images to get
clusters of pure pixel values.
2. Convert to vector.
3. Create a random location of vector points.
4. From the converted vector layer, select random polygons
(approximately 60 polys for each class).
5. Label training polygons for the desired classification classes
6. Run smap classification
I will be running this method for a series of LANDSAT images (one tile
at a time).
My problem is by converting the whole image from raster to vector
areas, the v.to.rast module reports "Killed" and could not complete
the conversion.
This maybe due to the whole image being large.
Type of Map: raster Number of Categories: 47 |
| Data Type: CELL |
| Rows: 7518 |
| Columns: 8504 |
| Total Cells: 63933072 |
| Projection: UTM (zone 51) |
| N: 746814 S: 532551 Res: 28.5 |
| E: 857451 W: 615087 Res: 28.5 |
| Range of data: min = 1 max = 47
I've tried r.neighbors to reduce number of areas with less than 1-10
pixels, but this process outputs vectors layers with mixed pixel
values, thus making it difficult to use in MLC or SMAP as training
areas.
What I need is to, limit raster to vector conversion to the desired
randomly selected locations only. So that r.to.vect could complete the
conversion.
Any ideas?
maning
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
images (one tile at a time).
the conversion.
Yes, that's an out of memory error. The operating system kills the offending processes so that the rest of the computer can keep running.
| Data Type: CELL
| Rows: 7518
| Columns: 8504
probably for sanity's sake you may want to stay under about 4000x4000.
It is not a hard limit, the only thing that should limit you for bigger sizes is computer resources and your time.
desired randomly selected locations only. So that r.to.vect could
complete the conversion.
Any ideas?
I've needed a similar thing a number of times, and so I've just added a new add-on script which may be helpful.
"g.region.point - g.region.point is a shell script which resets the computational region to a square box around a given coordinate. It is intended for use within GRASS scripts to speed up processing by focusing expensive raster calculations onto a small area of interest."
On Mon, 2008-06-23 at 10:25 +0200, Markus Neteler wrote:
On Mon, Jun 23, 2008 at 5:46 AM, maning sambale
> conversion.
Did you try to set a raster mask (r.mask)? It should be respected
by r.to.vect.
Dear all,
I recently had to think about a similar problem. But the question
remain... how can raster areas be selected based on vector points that
fall inside them?
Assuming there is a raster map with areas (e.g. the result of a classification).
Ok, now it's clear. That's a good point... maybe one could write an
algorithm similar to r.grow or r.lake: add pixels starting from a
point until a pixel with the same category of the seed is found.
A good exercise
has the previous suggested (weeks/months?) method worked?
(r.what or v.what.rast) -> r.reclass -> MASK -> 'g.region zoom='
'g.region zoom=' may be a bit slow; I don't know if that can be improved.
ISTR that it starts at the current region, not the map bounds, which might help speed things up if you want to zoom in on just one patch. (??)
G. Allegri:
(r.what or v.what.rast) -> r.reclass -> r.grow -> 'g.region rast='
r.reclass would reclass all the areas having the same value as the one
from r.what, so it's not guaranteed that just the area around the
specified point is considered. Am I wrong?
Are you sure r.grow is useful? As far as I've unserstood it makes a
sort of r.buffer+r.patch, based on a buffer radii, not inspecting the
pixel values...
Yes r.mapcalc can do the work, but I was tinking to something like
r.lake... Maybe it's more performant. Ok, proabibly it should be
written with a C routine not bash.
as the one from r.what, so it's not guaranteed that just the area
around the specified point is considered. Am I wrong?
that is correct; all of that value in the map.
a sort of r.buffer+r.patch, based on a buffer radii, not
inspecting the pixel values...
oops, I meant r.cost.
well bash is nice for prototypes and proof of concept. You can worry about C later if you can't stand the slowness. Usually you can stand it.
I've never used r.lake much, so can't comment on if it could offer a solution.
random idea:
Maybe we could add a "module of the day" feed on the grass webpage with module name and label/description one-liner. I continue to find new modules many years after first using grass.
random idea:
The same with me; not only am I discovering new modules, but also discovering flags present in old modules I've used for years that I wish I had known about years ago!
