[GRASS-user] r.univar: different results with different projections?
Hi all.
I’m analyzing some global-scale DEMs, like ETOPO1/2, SRTM30_PLUS, etc.
I’m getting the statistics for the whole dataset with r.univar, but today I noticed that the results differ if I use different projections. (GRASS 7.1)
For example, ETOPO2:
Using a latlong pseudo-projection (plate carré)
min: -10791
max: 8440
mean: -1888.6480792
median: -2457
stddev: 2650.01922839
p25: -4273
p75: 216
And using equal-area cylindrical:
min: -10791
max: 8440
mean: -2379.78247747
median: -3291
stddev: 2507.89668617
p25: -4541
p75: 94
Are these differences expected? I would think that they should be the same, regardless of projection (I’m thinking on the elevation values as an array of values).
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
Hello Carlos,
Maybe it has something to do with the pixel resolution? I would certainly expect the same results, but with a very similar region (i.e. same number of rows and columns, or at least very close and a similar number of pixels)
Maybe when projecting the raster, the length of the array is varying but I wouldn’t expect to vary very much, are you getting the same results in a previous version of GRASS? (7.0 or even 6.4?)
Greetings
El nov. 16, 2015 11:35 AM, “Carlos Grohmann” <carlos.grohmann@gmail.com> escribió:
Hi all.
min: -10791
max: 8440
mean: -1888.6480792
median: -2457
p25: -4273
p75: 216
min: -10791
max: 8440
median: -3291
p25: -4541
p75: 94
thanks
Carlos
grass-user mailing list
grass-user@lists.osgeo.org
Hello Cesar
I wouldn’t expect pixel resolution to play a role here. The statistics must be carried out over the values.
The raster(s) I’m testing are rectangular, without null values. So reprojecting will change the pixel size (from a square to a rectangle), but it will (should) not change the number of pixels.
I’ll try in another GRASS version and post the results.
best
Carlos
On Mon, Nov 16, 2015 at 4:48 PM, César Augusto Ramírez Franco <caesarivs@gmail.com> wrote:
Hello Carlos,
Greetings
Hi all.
min: -10791
max: 8440
mean: -1888.6480792
median: -2457
p25: -4273
p75: 216
min: -10791
max: 8440
median: -3291
p25: -4541
p75: 94
thanks
Carlos
On Mon, Nov 16, 2015 at 5:34 PM, Carlos Grohmann
<carlos.grohmann@gmail.com> wrote:
Hi all.
I'm analyzing some global-scale DEMs, like ETOPO1/2, SRTM30_PLUS, etc.
I'm getting the statistics for the whole dataset with r.univar, but today I
Please post also *how* you reprojected (resampling method etc)
Ok, sorry about the incomplete post.
I reprojected from a latlong location to a cylindrical equal area projection, using the default nearest neighbor resampling method.
original location:
GRASS 7.1.svn (base_maps):~ > g.region -p raster=gdem_etopo1_ice
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
Equal area projection:
r.proj location=latlong mapset=base_maps input=gdem_etopo1_ice -g
Input map <gdem_etopo1_ice@base_maps> in location :
n=6363885.33192604 s=-6363885.33192604 w=-20037508.34278924 e=20037508.34278924 rows=10800 cols=21600
GRASS 7.1.svn (eqarea):~ > g.region -p n=6363885.33192604 s=-6363885.33192604 w=-20037508.34278924 e=20037508.34278924 rows=10800 cols=21600
projection: 99 (Equal Area Cylindrical)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 6363885.33192604
south: -6363885.33192604
west: -20037508.34278924
east: 20037508.34278924
nsres: 1178.49728369
ewres: 1855.32484655
rows: 10800
cols: 21600
cells: 233280000
GRASS 7.1.svn (eqarea):~ > r.proj location=latlong mapset=base_maps input=gdem_etopo1_ice
Here are the outputs of r.univar, for both locations:
Latlong
GRASS 7.1.svn (base_maps):~ > r.univar map=gdem_etopo1_ice -ge percentile=100
n=58320000
null_cells=0
cells=58320000
min=-10753
max=8333
range=19086
mean=-1892.08140334362
mean_of_abs=2644.85220128601
stddev=2650.12442373911
variance=7023159.46129855
coeff_var=-140.063974998956
sum=-110346187443
first_quartile=-4286
median=-2456
third_quartile=214
percentile_100=8333
Equal-area
GRASS 7.1.svn (eqarea):~ > r.univar map=gdem_etopo1_ice -ge percentile=100
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
mean=-2382.28934158093
mean_of_abs=2845.10169015775
stddev=2508.93105538271
variance=6294735.0406638
coeff_var=-105.315966939504
sum=-555740457604
first_quartile=-4544
median=-3285
third_quartile=93
percentile_100=8333
I also tested in python, flattening the raster to an array. The results are the same as r.univar (in both cases).
best
Carlos
Hi all.
Please post also how you reprojected (resampling method etc)
On Mon, Nov 16, 2015 at 8:47 PM, Carlos Grohmann
For continuous surfaces such as DEM I would use bilinear resampling method.
Best
Carlos,
2015-11-16 14:47 GMT-05:00 Carlos Grohmann <carlos.grohmann@gmail.com>:
cells: 233280000
cells=58320000
cells=233280000
​​Notice how the number of pixels differs, that’s the reason the statistics are not the same​, I don’t get why the region has a different number of pixels than the raster itself in the original latlong projection…​ I think that’s the root of the issue
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias - Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
http://labscn-unalmed.github.io/
Hello Cesar
That was weird, so I tested it again. The number of cells is the same for both projections, but the values differ. This must be related to reprojecting.
To me, they shouldn’t de different, since a nearest neighbor should preserve the original values. I’m not really comfortable with this, as I’m not sure I can trust the stats after projecting.
best
Carlos
GRASS 7.1.svn (latlong):~ > g.region raster=gdem_etopo1_ice -pa
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
GRASS 7.1.svn (latlong):~ > r.univar map=gdem_etopo1_ice -ge percentile=100
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
mean=-1892.40422534294
mean_of_abs=2644.91906490912
stddev=2649.98339302808
variance=7022411.98332463
coeff_var=-140.032629262802
sum=-441460057688
median=-2457
third_quartile=214
percentile_100=8333
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-555740457604
median=-3285
third_quartile=93
percentile_100=8333
On Mon, Nov 16, 2015 at 7:43 PM, César Augusto Ramírez Franco <caesarivs@gmail.com> wrote:
Carlos,
cells: 233280000
cells=58320000
cells=233280000
Dear Carlos,
I’m not an expert for projections.
However, on Lat/Long WGS84 the actual area of cells decline from the equator towards the poles.
Thus, I would expect that cell values near the poles have “more weight” using Lat/Long WGS84 than using an equal area projection.
Near the poles I don’t understand how the values for extent and resolution should be correct (equal area), except there is a huge distortion (very likely for a cylindrical projection)!
Are there really 21600 cols with a nsres = 1178 m at the north and south pole. I would call this a huge distortion.
As a test, I would calculate the statistics for a smaller area centered at the equator. I would expect that the results are very similar comparing the lat/long and the reprojected dataset.
Regards Jörg
Hello Cesar
best
Carlos
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-441460057688
median=-2457
third_quartile=214
percentile_100=8333
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-555740457604
median=-3285
third_quartile=93
percentile_100=8333
Carlos,
cells: 233280000
cells=58320000
cells=233280000
Hello Jörg
The area of cell shouldn’t influence here. The statistics are about the elevation values, regardless of the area represented by pixel. If I think on the pixels as equally-spaced vector points, after projection they won’t be equally-spaced anymore, but the number of points won’t change. So the mean of their values (and stddev, etc) shouldn’t change as well.
regards
Carlos
On Tue, Nov 17, 2015 at 5:15 AM, Robl Jörg Christian <Joerg.Robl@sbg.ac.at> wrote:
Dear Carlos,
Regards Jörg
Von: grass-user [mailto:grass-user-bounces@lists.osgeo.org] Im Auftrag von Carlos Grohmann
Gesendet: Montag, 16. November 2015 23:32
Cc: GRASS user list
Betreff: Re: [GRASS-user] r.univar: different results with different projections?
Hello Cesar
best
Carlos
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-441460057688
median=-2457
third_quartile=214
percentile_100=8333
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-555740457604
median=-3285
third_quartile=93
percentile_100=8333
Carlos,
cells: 233280000
cells=58320000
cells=233280000
On Tue, Nov 17, 2015 at 7:56 AM, Carlos Grohmann <carlos.grohmann@gmail.com>
wrote:
Hello Jörg
The area of cell shouldn't influence here. The statistics are about the
on the pixels as equally-spaced vector points, after projection they won't
be equally-spaced anymore, but the number of points won't change. So the
mean of their values (and stddev, etc) shouldn't change as well.
I don't think you can treat pixels as vector points here, I agree with what
Jörg was saying. If some vector points would get further away, you will get
new pixels in between and if the points get close enough, the information
in all points but one is lost. This is at least my intuitive understanding
of the NN reprojection which can be wrong. I wouldn't be concerned that the
results changed but how much they changed.
Anna
regards
Carlos
> wrote:
Dear Carlos,
Regards Jörg
*Von:* grass-user [mailto:grass-user-bounces@lists.osgeo.org] *Im
Auftrag von *Carlos Grohmann
*Gesendet:* Montag, 16. November 2015 23:32
*Cc:* GRASS user list
*Betreff:* Re: [GRASS-user] r.univar: different results with different
projections?
Hello Cesar
reprojecting.
To me, they shouldn't de different, since a nearest neighbor should
preserve the original values. I'm not really comfortable with this, as I'm
best
Carlos
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
percentile=100
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-441460057688
median=-2457
third_quartile=214
percentile_100=8333
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 10800
cols: 21600
cells: 233280000
percentile=100
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-555740457604
median=-3285
third_quartile=93
percentile_100=8333
Carlos,
cells: 233280000
percentile=100
cells=58320000
cells=233280000
​​Notice how the number of pixels differs, that's the reason the
statistics are not the same​, I don't get why the region has a different
projection...​ I think that's the root of the issue
*César Augusto Ramírez Franco*
- Digital Terrain Analysis | GIS | Remote Sensing -
________________
________________
Yes Anna you’re right. New pixel will be created and some might be lost.
But the changes in the statistics is what concerns me. If your statistical description of a raster changes significantly after reprojection, which one is right?
On Tue, Nov 17, 2015 at 12:50 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Tue, Nov 17, 2015 at 7:56 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Hello Jörg
I don’t think you can treat pixels as vector points here, I agree with what Jörg was saying. If some vector points would get further away, you will get new pixels in between and if the points get close enough, the information in all points but one is lost. This is at least my intuitive understanding of the NN reprojection which can be wrong. I wouldn’t be concerned that the results changed but how much they changed.
Anna
regards
Carlos
Dear Carlos,
Regards Jörg
Cc: GRASS user list
Hello Cesar
best
Carlos
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:01
ewres: 0:01
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-441460057688
median=-2457
third_quartile=214
percentile_100=8333
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 10800
cols: 21600
cells: 233280000
n=233280000
null_cells=0
cells=233280000
min=-10803
max=8333
range=19136
sum=-555740457604
median=-3285
third_quartile=93
percentile_100=8333
Carlos,
cells: 233280000
cells=58320000
cells=233280000
On 17/11/15 16:13, Carlos Grohmann wrote:
Yes Anna you're right. New pixel will be created and some might be lost.
Depending on how much you trust the resampling methods, both are "right" in their projection system and using this resampling method. :wink:
Look at your resolution: in the projected systems your pixels are strongly rectangular:
This makes a difference as to which pixels are seen to be the nearest neighbors. By displaying the map in both systems side by side and by zooming very closely you can see this quite clearly. Pixels are not equal to pixels when moving from one projection system to another. The grid you lay over the earth is different and so the statistics calculated from that grid will be different as well.
Have a look at the attached screenshot. You can see the etopo data on the coast of greenland in EPSG 4326 and in a "World Mercator" system (+proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000 +to_meter=1).
The values I got was from the right-hand land pixel just above the central water area. As you see values are different, as these pixels are not equal.
Reprojection of raster maps is not the same as reprojection of vector maps in which you reproject the vertices of an object, but the attributes of that object remain the same. As explained in the r.proj manual:
"A raster may be considered o represent a sampling of a process at a regular, ordered set of locations. The set of locations that lie at the intersections of a cartesian grid in one projection will not, in general, coincide with the sample points in another projection. Thus, the conversion of raster maps involves an interpolation step in which the values of points at intermediate locations relative to the source grid are estimated."
Moritz
    <carlos.grohmann@gmail.com <mailto:carlos.grohmann@gmail.com>> wrote:
        Hello Jörg
        points, after projection they won't be equally-spaced anymore,
        but the number of points won't change. So the mean of their
    wrong. I wouldn't be concerned that the results changed but how much
    they changed.
    Anna
        regards
        Carlos
        <Joerg.Robl@sbg.ac.at <mailto:Joerg.Robl@sbg.ac.at>> wrote:
            Dear Carlos,____
            __ __
            I’m not an expert for projections. ____
            from the equator towards the poles. ____
            projection. ____
            __ __
            projection)!____
            north and south pole. I would call this a huge distortion.____
            __ __
            reprojected dataset.____
            __ __
            Regards Jörg____
            __ __
            __ __
            __ __
            *Von:*grass-user [mailto:grass-user-bounces@lists.osgeo.org
            <mailto:grass-user-bounces@lists.osgeo.org>] *Im Auftrag von
            *Carlos Grohmann
            different projections?____
            __ __
            Hello Cesar____
            __ __
            must be related to reprojecting.____
            __ __
            should preserve the original values. I'm not really
            comfortable with this, as I'm not sure I can trust the stats
            after projecting. ____
            __ __
            best____
            __ __
            Carlos____
            __ __
            __ __
            -pa____
            projection: 3 (Latitude-Longitude)____
            zone: 0____
            datum: wgs84____
            ellipsoid: wgs84____
            north: 90N____
            south: 90S____
            west: 180W____
            east: 180E____
            nsres: 0:01____
            ewres: 0:01____
            rows: 10800____
            cols: 21600____
            cells: 233280000____
            percentile=100____
            n=233280000____
            null_cells=0____
            cells=233280000____
            min=-10803____
            max=8333____
            range=19136____
            mean=-1892.40422534294____
            mean_of_abs=2644.91906490912____
            stddev=2649.98339302808____
            variance=7022411.98332463____
            coeff_var=-140.032629262802____
            sum=-441460057688____
            first_quartile=-4286____
            median=-2457____
            third_quartile=214____
            percentile_100=8333____
            __ __
            __ __
            __ __
            __ __
            GRASS 7.1.svn (eqarea):~ > g.region -p____
            projection: 99 (Equal Area Cylindrical)____
            zone: 0____
            datum: wgs84____
            north: 6363885.33192604____
            south: -6363885.33192604____
            west: -20037508.34278924____
            east: 20037508.34278924____
            nsres: 1178.49728369____
            ewres: 1855.32484655____
            rows: 10800____
            cols: 21600____
            percentile=100 ____
            n=233280000____
            null_cells=0____
            cells=233280000____
            min=-10803____
            max=8333____
            range=19136____
            mean=-2382.28934158093____
            mean_of_abs=2845.10169015775____
            stddev=2508.93105538271____
            variance=6294735.0406638____
            coeff_var=-105.315966939504____
            sum=-555740457604____
            first_quartile=-4544____
            median=-3285____
            third_quartile=93____
            __ __
            __ __
            __ __
            __ __
            __ __
            __ __
            __ __
            Franco <caesarivs@gmail.com <mailto:caesarivs@gmail.com>>
            wrote:____
            Carlos,____
            __ __
            <mailto:carlos.grohmann@gmail.com>>:____
            raster=gdem_etopo1_ice____
            __ __
            -ge percentile=100____
            cells=58320000____
            __ __
            percentile=100____
            cells=233280000____
            __ __
            the statistics are not the same​, I don't get why the region
            the original latlong projection...​ I think that's the root
            of the issue____
            __ __
            -- ____
            Teléfono: (57-4) 430 9369 - 300 459 6085____
            http://labscn-unalmed.github.io/____
            ____
            __ __
            -- ____
            Brazil____
            - Digital Terrain Analysis | GIS | Remote Sensing - ____
            __ __
            http://carlosgrohmann.com/&gt;\_\_\_\_
            http://orcid.org/0000-0001-5073-5572____
            ________________
            Can’t stop the signal.____
        ________________
        grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
________________
(attachments)
