[GRASS-user] r.viewshed add-on is taking too long
Hello everyone,
I’ve been trying to compute some viewsheds using the r.viewshed module (available in http://grass.osgeo.org/wiki/GRASS_AddOns), but it’s taking to long to finish.
I ran this module on a 5000x5000 (95mb) raster grid and it took 3min 17sec to finish. I have seen some articles where it’s said that this module is capable of computing raster grids bigger than this one in 18 seconds. I also tested it on a bigger raster grid (33000x33000, 4.05gb), and it took almost 3 days to finish!
So, I was wondering if I’ve been doing something wrong, because the execution times seem to be much bigger than the expected.
I’m using an Intel Core 2 duo 2.93GHz, with 4GB RAM and Ubuntu 10.04 32bits. My GRASS version is GRASS 6.4.3svn. The command line I used was:
r.viewshed -b --overwrite input=r9_5000@PERMANENT output=vs_r9_5k coordinate=2500,2500 obs_elev=50 tgt_elev=50 memory=2000
I used coordinate=2500,2500 because the terrain bounds are X:0~5000 and Y:0~5000 and I wanted the observer to be sited at the center of it. I had tried to import this same raster grid (using r.in.bin) with smaller bounds (X:0~50 and Y:0~50) and to run r.viewshed with coordinate=25,25, but I received the following assertion error:
Determine visibility…
r.viewshed: statusstructure.cpp:73: float get_vertical_angle(Viewpoint, StatusNode, surface_type, int): Assertion `fabs(sn.dist2vp) > 0.001’ failed.
Aborted
Does anyone use this Add-on and has some running times to show me and compare with mine? Or does someone knows if I am doing something wrong?
Chaulio Ferreira
On Tue, Jun 12, 2012 at 9:52 PM, Chaulio Ferreira <chaulio@hotmail.com> wrote:
Hello everyone,
I've been trying to compute some viewsheds using the r.viewshed module
(available in http://grass.osgeo.org/wiki/GRASS_AddOns), but it's taking to
long to finish.
to finish. I have seen some articles where it's said that this module is
3 days to finish!
So, I was wondering if I've been doing something wrong, because the
I'm using an Intel Core 2 duo 2.93GHz, with 4GB RAM and Ubuntu 10.04 32bits.
Since you are using a 32 bit OS, the amount of memory given to
r.viewshed (2000 MB) might be too large. Try with the default 500 MB.
The speed of r.viewshed depends on several factors: CPU speed,
available memory and disk IO speed. For very large input maps, disk IO
speed is the limiting factor, as long as the amount of memory
specified with the memory option is below the available free [0]
memory.
Markus M
[0] man free
Determine visibility...
StatusNode, surface_type, int): Assertion `fabs(sn.dist2vp) > 0.001' failed.
Aborted
Chaulio Ferreira
grass-user mailing list
grass-user@lists.osgeo.org
Markus M,
Thanks for answering. I’ll try to use the default 500mb. But I still think these differences in the times are too big. I am not using a big map (just 95mb, it would fit 5 times in the RAM memory) and a rather regular PC. On this email (http://lists.osgeo.org/pipermail/grass-dev/2008-October/040669.html) you said r.viewshed took 18 seconds, but for which map size? What are your computer configurations? If you ever made other tests on r.viewshed times, would you mind to show me the results?
Sorry for making so much questions, and thank you for the attention.
Chaulio Ferreira.
Date: Tue, 12 Jun 2012 23:59:58 +0200
Subject: Re: [GRASS-user] r.viewshed add-on is taking too long
To: chaulio@hotmail.com
CC: grass-user@lists.osgeo.org
On Tue, Jun 12, 2012 at 9:52 PM, Chaulio Ferreira chaulio@hotmail.com wrote:
Hello everyone,
long to finish.
3 days to finish!
memory.
Markus M
[0] man free
Aborted
Chaulio Ferreira
On Wed, Jun 13, 2012 at 12:21 AM, Chaulio Ferreira <chaulio@hotmail.com> wrote:
Markus M,
Thanks for answering. I'll try to use the default 500mb. But I still think
I was testing a bit and can confirm the differences. Still, r.viewshed
is much faster than r.los.
this email
That was the other Markus. The map size was probably around 10 million cells.
Sure! I'm still busy testing, will report results soon.
These are not that many questions, thanks for providing feedback!
Markus M
Chaulio Ferreira.
wrote:
> Hello everyone,
> to
> long to finish.
> 17sec
> also
> almost
> 3 days to finish!
> 32bits.
memory.
Markus M
[0] man free
> had
> bounds
> failed.
> Aborted
> Thanks,
> Chaulio Ferreira
