Hello Grass users,
I'm using r.viewshed to calculate the vertical height visible of object
(windturbine) from any point on my DEM. So, I iterate upto the maximum
height (from 0 to 250m) every meter. At the end, I made a r.series to
sum the maps. As I have sometimes about 300 wtg on the territory, it
takes a while (about two days) to calculate all the visibile height for
each wtg on a 80kmx80km territory with 75m resolution (1066x1066). But
it works.
Today, I need to calculate one wtg with a topo raster about 22000 rows x
22000 colums (5m resolution on about 50km radius = near 500 milions cells).
I wrote a new python script that parallelized jobs (inspired by
https://grasswiki.osgeo.org/wiki/Parallelizing_Scripts). But I notice
that the proc are running at 100% a small part of the time and the
memory not so much used. On the other hand, the hdd is very busy.
I'm using Grass 7.4 on Debian 9 with Intel i7 (8 cores) and 32Go RAM.
And I have setup 4096MB per r.viewshed and directory=/tmp
I wonder if it's not better to use only one core and put 32GB memory on
the one calculation ? What are the best settings to improve calculation
speed ?.
Or is there any other faster approach to calculate the visibility ? (I
had been thinking with r.horizon to calculate the minimum visible
height. But unfortunatly the raster mode is not able to give horizon to
a specific target coordinates, unless to do it for each cell
independently...)
See below a part of output (the script is still running)
GRASS_INFO_END(13720,1)
Estimated size active structure:
(key=64, ptr=8, total node=96 B)
Total= 2103840 B
Start sweeping.
Computing events...
Nodata value set to -nan
rows=21915, cols=21915, total = 480267225
In-memory memory usage is 48026897820 B (45802 MB), max mem
allowed=4294967296 B(4096MB)
***** EXTERNAL_MEMORY MODE *****
Intermediate files will not be deleted in case of
abnormal termination.
Intermediate location: /media/hdd1/temp/
To save space delete these files manually!
Total= 2103840 B
Start sweeping.
Computing events...
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
Sorting events...
Sorting events...
Sorting events...
Sorting events...
Sorting events...
Sorting events...
Sorting events...
Sorting events...
Initialize sweepline...
Determine visibility...
the /tmp directory content is :
16 files, for 369 Go
The maps are created by series of 8 (in 4 hours), but Grass needs
between 24h upto 36h between two sets of 8 maps...
Thank you for your help.
Frank
