[GRASS-user] r.vol.dem error on Windows
Dear Grass users,
I’would like to create a 3D voxel from my geological surfaces with r.vol.dem modul.
I use the Windows version of GRASS.
The checking and interpolation section work, but could not create the voxeltmp.tmp file.
Have you any idea to solve this problem?
Thank you
Tunde
"C:>r.vol.dem -f --overwrite input=Battonya_Base_Shift_fl@tifek,Battonya_Rift_initiation_Shift_fl@tifek,Battonya_Rift_climax_Shift_fl@tifek,Battonya_Base_slope_Shift_fl@tifek,Battonya_Top_slope_Shift_fl@tifek,Battonya_srtm_Shift_fl@tifek output=proba@tifek algorithm=down
Validating data:
Z-range checking, pass 1:
100%
z-range-checking, pass 2:
100%
Checking DEM topologies:
100%
Interpolating:
100%
ERROR: Could not create temporary file for writing ASCII output
(voxeltmp.tmp)"
Tünde Tóth <tundetothgis@gmail.com> schrieb am Fr., 23. Juli 2021, 11:34:
Dear Grass users,
I suppose that Windows dislikes the plain definition of TMPFILE without path:
https://github.com/OSGeo/grass-addons/blob/5775eb7806a36aa8d00dbf6e1603f3e1a197c5ca/grass7/raster/r.vol.dem/globals.h#L20
The common temp file mechanism isn’t used here (yet)…
Best
Thank you
Tunde
Validating data:
100%
100%
100%
Interpolating:
100%
(voxeltmp.tmp)"
grass-user mailing list
grass-user@lists.osgeo.org
