Hi everyone,
I have some doubts with the generation of a cost surface with r.walk . It’s assumed that the resulting layer is measured in seconds, but when I try to convert seconds in days march (6h per day), the resulting layer has no sense.
This is the workflow I’m following:
1st.- I have several vector layers as roads, rivers, bridges, and a raster layer of elevation.
2nd.- Rasterize the vector layers with a field named “weight” (PESO in spanish) where I have weighted this variables according to if they facilitate the walking or not. Reclassify is made if it’s needed.
3rd.- Find Slope (in percent) layer and reclasify as follow:
0-10=1;
11-maxValue=100
4th.- r.cross with all the rasterized layer. (roads, bridge, river and reclassified slope).
5th.- I create a new friction layer using this formula proposed by Pandolf (1977) with r.mapcalc :
M=1.5W+2.0(W+L)(L/W)^2+"CrossedLayer"*(W+L)(1.5V^2+0.35V*abs("SlopeLayer"+10))
6th.- With this layer measured in Watts I use r.walk with default parameters.
7th.- Once obtained this layer measured in seconds I try to convert it in hours dividing 3600 and then convert these hours in days march dividing 6 (6 hours per day).
Well, the results are not what I expected, the max data of this layer is about 8.000… No sense, it should be something like 3 or 4 days, maybe.
Here are the files I’m using to do this workflow.
I don’t know what I’m missing, maybe is the 4th step wrong? Maybe the 5th?
Another point of view would be nice to me. If you need more info, please ask for it and I will add to the question.
Thank you very much to everyone.
Thanks a lot!
