Using the new ASTER DEM data it seems to me that the resolution is good enough to show the elevation of the road surface on bridges crossing a riverbed. I see some places where the delineated stream comes to a bridge, then, instead of going under the bridge, turns 90 deg and runs along the road to a low spot, then crosses. So the bridge is "seen" a dam. What's the best way to deal with this? r.carve? or just locally editing the raster somehow?
Micha
If you have a small region and you know, where the bridges are, I guess
fastest method is to do it manually.
Otherwise r.carve would do good here.
To find bridges maybe the gradient of hight will help (slope).
Best regards,
Achim
Micha
grass-user mailing list
grass-user@lists.osgeo.org
