[GRASS-user] r.watershed, blocking, and max_slope_length
Hi List,
I can't seem to get blocking or max_slope_length to work as I would expect. I see no change to the output when I use them.
I'm calling =r.watershed= like this:
r.watershed -s -a --v --overwrite --verbose elevation=z_s flow=RU85 blocking=z_2000_r thresh=50 max_slope_length=11000 accumulation=tmp.acc
Where =v_200_r= is a raster of a single contour at 2000 made with:
r.contour input=z_s output=z_2000_v levels=2000 --o
v.to.rast --overwrite --verbose input=z_2000_v type=line output=z_2000_r use=z
Based on the =r.watershed= documentation, I would expect two things:
1. All flow routing stops at 2000 m and then restarts below.
2. No flow continues more than 11 km, which is not far because I'm on a 5 km grid.
Instead I see the exact same results as if I did not use either of those keywords.
Although I'd like to understand these keywords, I'm also curious if my planned usage makes sense. I need to route all surface water 1 cell downstream as part of this analysis (actually 1 cell downstream if slope is < 0.5). I plan to do this by generating an accumulation map with max distance of 7.5 km (on a 5 km grid). I assume this routes everything only 1 cell, whether 90 degrees (5 km) or 45 degrees (7.07 km). Then I subtract this accumulation map from the original, and the result is the input flow map but moved 1 cell downstream.
Thanks for any help you can provide,
  -k.
P.S. Using grass 7.0.3 on OS X installed with 'brew' and no Framework packages. Works quite nicely.
Hi again,
Perhaps some MWEs with the NC data set will help demonstrate what I'm doing and presumably doing wrong...
Here I'm setting max_slope_length to 15 (g.region -p shown the resolution is 10) so I would expect flow to only move ~1 grid cell. But the accumulation map is identical to running r.watershed w/o the max_slope_length setting.
r.mapcalc "rain = 1"
r.watershed -s -a --v elevation=elev_srtm_30m accumulation=acc drainage=fdir flow=rain
r.watershed -s -a --v elevation=elev_srtm_30m accumulation=acc.len drainage=fdir.len flow=rain max_slope_length=15
g.gui.mapswipe first=acc second=acc.len
And here, I'm trying to block flow from crossing the 30 m elevation contour:
r.contour input=elev_srtm_30m@PERMANENT output=z_30_v levels=30
v.to.rast --overwrite --verbose input=z_30_v type=line output=z_30_r use=z --overwrite
r.watershed -s -a --v elevation=elev_srtm_30m accumulation=acc.block drainage=fdir.block flow=rain blocking=z_30_r
g.gui.mapswipe first=acc second=acc.block
  -k.
