[GRASS-user] r.watershed G_malloc error
Michael Spencer wrote:
I'm on windows xp using GRASS 6.4 and 7 and I'm getting the
following error running r.watershed:
ERROR: G_malloc: unable to allocate 2521456396 bytes of memory
at init_vars.c:137
I've 2Gb of ram and the dtm I'm using is 185Mb in (pre import)
ascii grid format, so not massive. Is the above error because
I'm short on ram for the above process, or is it something else?
2521456396 / 1024000 = 2462.4 mb RAM req'd. XP gobbles about
270mb in standby (+ virus checkers etc), so you're about a
gigabyte over your limit. Can you work on a smaller region or
coarser resolution? (how many rows x columns? "g.region -p")
-or- you don't need that much more RAM; memory's pretty cheap.
Hamish
