[GRASS-user] r.watershed multi flow direction
I am using GRASS 6.4.0RC5+39438 (downloaded from svn server). I would like to obtain basins and stream segments from digital elevation data using the multi flow option in r.watershed as proposed in the documentation. The installed version of r.watershed obviously doesn't support this feature:
Sorry, <f> is not a valid flag
Sorry, <convergence> is not a valid parameter
Is there another version of the program available supporting this function?
Thank you in advance,
best regards,
Kristian Förster
I believe that MFD in r.watershed is in versions 6.5 and up.
Mark
On Fri, May 21, 2010 at 7:27 AM, Kristian Foerster <k.foerster@tu-bs.de> wrote:
best regards,
Kristian Förster
grass-user mailing list
grass-user@lists.osgeo.org
Furthermore, in version 6.5 and up r.watershed becomes veryvery fast!
Am 21.05.2010 14:05, schrieb M S:
Mark
On Fri, May 21, 2010 at 7:27 AM, Kristian Foerster<k.foerster@tu-bs.de> wrote:
Sorry,<f> is not a valid flag
Sorry,<convergence> is not a valid parameter
best regards,
Kristian Förster
Thank you all for your help. The new r.watershed version (GRASS 6.5) works fine and it's very fast :wink:
best regards
Kristian Förster
Mark
best regards,
Kristian Förster
On Fri, May 21, 2010 at 1:27 PM, Kristian Foerster <k.foerster@tu-bs.de> wrote:
You need to update your 6.4 installation. It has been backported by Markus Metz
3 weeks ago:
http://trac.osgeo.org/grass/changeset/42121
A simple
svn up
in your source code directory should get all updates for you.
