[GRASS-user] r3.mapcalc / r.mapcalc: Logical Operators &&, || behave differently
for r3.mapcalc and r.mapcalc, there seems to be a difference regarding the logical operators (&& ||, etc.):
Assuming that two raster maps BAR and BAZ exist, the following statement creates new map content FOO whenever BAZ and BAR are not null:
r.mapcalc FOO='if((BAZ && BAR),42,null())'
Doing the same with volumes (BAZ3, BAR3) results in an error message:
r3.mapcalc FOO3='if((BAZ3 && BAR3),42,null())'
Incorrect argument types to function or()
Parse error
Where's my mistake ?
FWIW: I'm using GRASS6.4.2 on Linux
GRASS 6.4.2 (2012)
Revision: 45934
Best,
Peter
<peter.loewe@gmx.de>
null:
Not quite.
The result will be 42 if both BAZ and BAR are non-null and non-zero.
If either are null or either are zero, the result will be null.
Regarding &&:
* A && B is null if either A or B are null, otherwise ...
* A && B is zero if either A or B are zero, otherwise ...
* A && B is one.
Regarding if():
* if(A,B,C) is null if A is null, otherwise ...
* if(A,B,C) is B if A is non-zero, otherwise ...
* if(A,B,C) is C
So if either BAZ or BAR are null, (BAZ && BAR) will be null and the
if() function will evaluate to null regardless of its second and third
arguments.
If neither are null, then (BAZ && BAR) will be 0 if either BAZ or BAR
are zero, and 1 if both are non-zero.
FWIW, you should change the quoting to:
  r3.mapcalc 'FOO3 = if((BAZ3 && BAR3),42,null())'
This will work in both 6.x and 7.x, whereas your original version will
only work in 6.x (in 7.x, r.mapcalc/r3.mapcalc use the GRASS argument
parser, so the expression musn't match the "option=value" syntax;
adding spaces around the "=" avoids this issue).
Parse error
I suspect that either BAZ3 or BAR3 is a floating-point volume. The
arguments to logical operators must be integers.
Also, I don't see how you can get a reference to "or()" from an
expression involving only "&&".
Glynn,
thanks for your quick response:
You are of course correct regarding the non-null/non-zero aspects and I stand corrected for the substellar cut'n past blunder :slight_smile:
Yet still I'm puzzled, as I hoped that type casting to INT would do the trick:
r3.mapcalc l01i='int(l01)'
r3.mapcalc l02i='int(l02)'
GRASS 6.4.2 (utm10n_wgs84):~ > r3.mapcalc "FOO3 = if((l01i || l02i),42,null())"
Parse error
same here:
GRASS 6.4.2 (utm10n_wgs84):~ > r3.mapcalc "FOO3 = if((l01i && l02i),42,null())"
Incorrect argument types to function and()
Parse error
FWIW, the volumes are quite trivial:
GRASS 6.4.2 (utm10n_wgs84):~ > r3.info l01i
| Layer: l01i Date: Wed Aug 20 22:32:46 2014 |
| Mapset: PERMANENT Login of Creator: ploewe |
| DataBase: /home/cegit/ploewe/geodata/locations |
| Title: ( l01i ) |
| Timestamp: none |
| Type of Map: 3d cell Number of Categories: 0 |
| Data Type: double |
| Rows: 1400 |
| Columns: 979 |
| Depths: 188 |
| Total Cells: 257672800 |
| Projection: UTM (zone 10) |
| N: 5121985 S: 5107985 Res: 10 |
| E: 567605 W: 557815 Res: 10 |
| T: 2550 B: 670 Res: 10 |
| Range of data: min = 1 max = 1 |
| Data Source: |
| Data Description: |
| generated by r3.mapcalc |
| Comments: |
| r3.mapcalc |
Any further advice would be much appreciated.
Best,
Peter
Gesendet: Mittwoch, 20. August 2014 um 22:14 Uhr
Von: "Glynn Clements" <glynn@gclements.plus.com>
An: "Peter Löwe" <peter.loewe@gmx.de>
Cc: grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] r3.mapcalc / r.mapcalc: Logical Operators &&, || behave differently
> null:
Not quite.
Regarding &&:
* A && B is one.
Regarding if():
* if(A,B,C) is C
arguments.
> Parse error
It appears that 3D volumes are always floating-point.
So you would need to use e.g.
  r3.mapcalc "FOO3 = if((int(l01) || int(l02)),42,null())"
or
  r3.mapcalc "FOO3 = if((l01 != 0 || l02 != 0),42,null())"
