[GRASS-user] raster analysis sectorwise as in a pie chart
I would like to analyse elevation data (slope, aspect, etc) around a point with
a defined radius. For my analysis I would like to devide that circle into
several sectors 1,5,10,x degree steps, like a pie.
Is that possible in GRASS? Are there people who did something similar? Any hints
and ideas are welcome.
regards,
Otto
point with a defined radius. For my analysis I would like to devide
that circle into several sectors 1,5,10,x degree steps, like a pie.
something similar? Any hints and ideas are welcome.
r.reclass into range bands, then
d.histogram style=pie (perhaps rendered into a corner sub- d.frame)
or somehow into a vector DB + 'd.vect.chart ctype=pie'
Hamish
On Tue, 27 Jan 2009 15:46:02 -0800 (PST)
thanks for your suggestion, but maybe my description was not very clear. I would
like to split data into spatial sectors and then start my analysis. E.g.:
a) Create a 1km buffer around a coordinate
b) Split this circle into sections (subareas) with a certain degree value. If I
choose 1 degree the circle would be devided into 360 subareas
c) Do my analysis in each sector
I am thinking about a solution for b)
regards,
Otto
With v.buffer you can create a circle. Then with a bit of geometry [1] you
can calculate the angles and more (perhaps implement in a shell/python
script) and then generate the lines and centroids with v.edit.
Finally rebuild the topology to obtain sector areas (v.build).
Hope this helps,
[1] essentially, radius of circle, angle, school geometry :slight_smile:
