I'm a new grass user and have been learning on the command line. I have a raster file of the world in which the cells are floating point values of the percentage of a crop type within that cell (ex., 0.01, 0.29, 0.45). It's in Lat/Long. I want to calculate the total area of crop in specific regions that are defined in a separate raster file. I want to multiply the value of the cell by the cell area and then sum the cell values in each region to get total acreage. My questions are: 1) Can I do this in r.stats, r.report or r.coin, or do I need to use r.mapcalc?, and 2) Because my files are in lat/long, the area covered by each cell changes based on its latitude. Can this be accounted for in trying to come with total area?
Thanks in advance for any suggestions to a grass newbie,
see also r.statistics, r.sum, r.univar, r.reclass(.area), ....
I'm not enough of an expert with using the cover map functions to answer this well. Regardless r.mapcalc should be flexible enough to do what you like as a worst case scenario.
sounds like a fairly standard & straight forward task though.
AFAICT from a quick look at the code, r.report and r.coin are just
friendly front-ends to r.stats. So the question reduces to: does
r.stats account for changing cell area with latitude? -- It does.
specifically r.stats calls these libgis functions:
G_begin_cell_area_calculations()
G_area_of_cell_at_row()
If you like, reproject the maps to an equal-area map projection and double check that the results are similar.
if you were really keen you could try to write your own module in C or with the swig/python interface for the calc. But the existing modules should give you all the tools you need from the command line.
and I haven't found in r.stats or related commands that allows an intermediate multiplication step. I have tried using r.proj (and with -n) to reproject to an equal area projection, but my crop maps are global coverages and the other Locations in lambert equal area are for the US, so the result is my global crop maps get clipped to the US.
Thanks very much,
Jerry
Hamish wrote:
Hi Jerry,
These are C functions; they don't exist in r.mapcalc.
If you can't use a global equal-area projection, you could just use
the underlying equations within r.mapcalc. Depending upon the required
accuracy, multiplying by cos(y()) might be sufficient. Otherwise, see
lib/gis/area_ellipse.c for the equations used.
Jerry Griffith wrote:
> Ok, since GRASS does account for differing cell size
> in lat/long raster files, what I am after is mapcalc is
> to do something like:
> croparea = [cellsize] * corn_map (my corn_map has a
> floating point value, ex. 0.29 that gives the fraction of the
> cell that is in corn cultivation)
> I have tried simply typing in for [cellsize] the
> functions listed below,
> but that doesn't work or my syntax is wrong.
Glynn:
Otherwise, see lib/gis/area_ellipse.c for the equations used.
perhaps this is a nice task for the SWIG/python interface?
see swig/python/examples/rasteraccess.py
