Good evening,
I'm looking for some way of accessing/using the raster attribute table of some data I have ... unfortunately I suspect it is from Arc. Searching on-line I haven't found anything that points me to GRASS tools to import/read raster attribute tables... Is it supported?
Here's a sample list of the files I have:
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
Otherwise you could import the raster map and then the attribute table with db.in.ogr.
From the table you could then build reclass rules for r.reclass.
(Not tested)
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Bartolomei.Chris
Sent: torsdag 20. september 2018 21:47
To: grass-dev@lists.osgeo.org; GRASS user list <grass-user@lists.osgeo.org>
Subject: [GRASS-user] Raster Attribute Tables
Good evening,
grass-user mailing list
grass-user@lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/grass-user
(Not tested)
Good evening,
I’m looking for some way of accessing/using the raster attribute table of some data I have … unfortunately I suspect it is from Arc. Searching on-line I haven’t found anything that points me to GRASS tools to import/read raster attribute tables… Is it supported?
Here’s a sample list of the files I have:
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations – including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations – and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
Thank you for the tip Stefan - most appreciated! I'll give that a try and report back.
Chris
From: Stefan Blumentrath <Stefan.Blumentrath@nina.no>
Sent: Thursday, September 20, 2018 4:36 PM
To: Bartolomei.Chris <Bartolomei.Chris@ensco.com>; GRASS user list <grass-user@lists.osgeo.org>
Subject: RE: Raster Attribute Tables
(Not tested)
Stefan
Good evening,
yes, r.in.gdal can dump raster attribute tables as csv files. Moreover, information in raster attribute tables is automatically imported as long as the field definitions contain information about how to use a field, e.g. for color information or for labels.
I don’t think db.in.ogr can read raster attribute tables: raster attribute tables are not equivalent to vector attribute tables.
Markus M
(Not tested)
Good evening,
BTW: I have added that to the manual page of r.in.gdal.
