Dear GRASS user,
how can I obtain the boundings of raster subpart like the minimum rectangle
around a certain category. I need it to specify the region for a
computationally intensive operation on a small part of the entire raster. The
problem I have is the mapcalc step to operate with huge raster datasets
containing "novalue" data mainly together with only small categorized areas.
Defining a mask a
mask for the relevant value doesnt work - the mapcalc takes the same long(!)
time as without a mask. So specifying region is the next idea.
Thanks a lot for some solution...
Christian.
This mail was sent through http://webmail.uni-jena.de
Just an idea:
1) Create new map with r.reclass where MyCat=1 OtherData=NULL and
2) then use g.region zoom=myreclassmap
Hope this helps,
Maris.
2008/5/6, Christian Schwartze <Christian.Schwartze@uni-jena.de>:
Dear GRASS user,
The
Defining a mask a
Christian.
grass-user mailing list
grass-user@lists.osgeo.org
Thanks - it works! So better reading the help pages...
But
unfortunately a little bit to slow when applying on large raster...
Best regards,
Christian.
Am Dienstag, den 06.05.2008, 17:28 +0300 schrieb Maris Nartiss:
Just an idea:
Hope this helps,
Maris.
> Dear GRASS user,
> The
> Defining a mask a
> Regards,
> Christian.
