[GRASS-user] raster data from one location to another
Hi list. Sorry for the very basic question. I can not find a convincing way to do it myself.
I need to copy a raster map from one location to another. I’ve think this options:
  • use a intermediary format, like ASCII
  • use r.pack/r.unpack
  • copy manually the files needed. I think that the files needed are all files named with the same name that the source layer, and that are under directories named “cell
I’ve searched in google and in documentation, but I’m sure that exist some better solution. Thanks for any advice.
Saludos
José María
To transfer from one location to another take a look at r.proj
It's used to do projection transformation and it does so by copying
from one location to another.... I guess it should work if both
locations have the same projection, that is, copy from one location to
another
DAniel
On Thu, Dec 11, 2008 at 12:23 PM, José María Michia
to do it myself.
I need to copy a raster map from one location to another. I've think this
options:
- use a intermediary format, like ASCII
- use r.pack/r.unpack
- copy manually the files needed. I think that the files needed are all
directories named "*cell*"
I've searched in google and in documentation, but I'm sure that exist some
Saludos
José María
grass-user mailing list
grass-user@lists.osgeo.org
another
if the projections are the same, I'd just create a new mapset, g.copy
the map(s) into it with 'g.copy map@othermapset,map', then move the mapset
directory over.
not ideal, but it works better than anything else.
Hamish
2008/12/11 Daniel Victoria <daniel.victoria@gmail.com>:
another
I've tried r.proj as you suggest. The problem is that source location
don't have projection information. Is a XY location. Not georrefenced
location.
I've used this location to fix the extents of a raster map. I get
wrong extents when import some tifs. r.in.gdal reports invalid values
(i.e., lon>180). But, I've solved this problem by editing the TFW
file manually (I think that this is correct approach).
Thanks Daniel.
DAniel
to do it myself.
options:
Saludos
José María
2008/12/12 Hamish <hamish_b@yahoo.com>:
another
directory over.
Hamish
This solution sounds more indicated to my original problem. I not need
anymore this operation. At least for now, I have much exciting GRASS
work to the future.
Thank very much Hamish, and all list people.
José María
