[GRASS-user] Raster displaying problem
I have the number of scanned maps (all are jpeg's with jgw referenced
files). All scans are not prepared by me, and all are scanned as whole
sheet (with legend and all other information). So when I display them in
grass or qgis, the legend of one sheet overlay the part of the next one
sheet (the screen shot is here: http://mort.no-ip.org/screen.png ).
Is there any way to don't display the part of raster file?? Or to cut
off those parts of scanned sheets??
Thanks
Radomir
The Future Is Now :wink:
set first your region to the inner region of the map.
then r.mapcalc newmap=originalmap
then g.region rast=otheroriginalmap,newmap
then r.patch input=otheroriginalmap,newmap output=patched
Hope that helps
Wolfgang
Radomir schrieb:
Thanks
but the problem is to define the region.
The map is in Polish coordinate reference system (EPSG 2180 - Poland
CS92) with kilometre grid. But the kilometre grid is not parallel to the
latitude/longitude grid. And the inner of the map is along
latitude/longitude. So if I define the region to the kilometre grid I
will still have small unwanted parts and I can't define the region to
the lon/lat grid.
Best regards,
Radomir
Hope that helps
Wolfgang
Radomir schrieb:
> Hi all,
> Thanks
grassuser mailing list
grassuser@grass.itc.it
Radomir
You can try to create a mask with r.digit, and then use r.resample
(without change region settings) to get a new map with data only
inside the mask.
Carlos
On 2/24/07, Radomir <dod.mort@gmail.com> wrote:
the lon/lat grid.
Best regards,
Radomir
Dnia 24-02-2007, sob o godzinie 21:12 +0100, WolfgangZillig napisa³(a):
> Hope that helps
> Wolfgang
> Radomir schrieb:
> > Hi all,
> > Thanks
Radomir
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
It works perfectly!!
Thank you,
Obrigado
Radomir
Dnia 24-02-2007, sob o godzinie 19:38 -0200, Carlos "Guâno" Grohmann
inside the mask.
Carlos
> Thanks,
> the lon/lat grid.
> Best regards,
> Radomir
> > Hope that helps
> > Wolfgang
> > Radomir schrieb:
> > > Hi all,
> > > Thanks
> > _______________________________________________
> Radomir
Radomir
