[GRASS-user] Raster map Calculator
Hello list,
I am trying to create a series of ratio images using grass 6.4.1 and I can’t get the syntax for the raster calculator figured out.
What I’ve got at the moment is:
‘Bar45rastfl = 1.0 * BarB40@PERMANENT / BarB50@PERMANENT’
I’ve tried varying the equation above but to no avail. The resulting maps do not contain any values.
What am I doing wrong?
Thanks in advance,
Michiel
On 19/03/12 20:42, Michiel Kunzel wrote:
Hello list,
can't get the syntax for the raster calculator figured out.
What I've got at the moment is:
'Bar45rastfl = 1.0 * BarB40@PERMANENT / BarB50@PERMANENT'
I've tried varying the equation above but to no avail. The resulting
Have you set your region correctly ?
I.e. g.region rast=BarB40
before running r.mapcalc ?
Moritz
Solved!
I don’t know whether this was the region, it seemed set valid, re-set it just to be sure.
Gave the same confusing result at first, but might have been the color table set wrong.
The results appeared to be integer with just one value, but resetting the colour table and performing a stretch gave readable results.
Thank you for your help.
Michiel
Date: Tue, 20 Mar 2012 09:13:35 +0100
To: mich_kun@hotmail.com
CC: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Raster map Calculator
Hello list,
Moritz
