Is there a way to get a subset of a larger raster map. I have zoomed
into an area and would like to make a raster map only containing that
area. Can I do this? I am going to use this as input into R for some
topmodel runs.
thanks,
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
I suggest you use spgrass6 package on R,
set your g.region using system(“g.region n= s= w= e=”)
on R and use readRAST6 to load your map
as SGDF. Of course, if you are under windows,
you know that depending the size of your grid
you will get troubles
topmodel runs.
thanks,
Stephen Sefick
Let’s not spend our time and resources thinking about things that are
On Fri, Feb 5, 2010 at 6:31 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Hi Stephen,
set your g.region using system("g.region n= s= w= e=")
best
milton
2010/2/5 stephen sefick <ssefick@gmail.com>
topmodel runs.
thanks,
Stephen Sefick
topmodel runs.
Stephen,
Yes, you can. This subject has come up several times in the past month or
so so the archives have a lot of options for you. One to look at closely is
v.in.region. After zooming to the area you want, run v.in.region and save
that vector map. You can then use it with the g.region command to limit the
displayed bounds of your raster map. You can use r.patch to make a new
raster map that's the size of the newly created vector map.
I am aware of r.topmodel in GRASS, but I am much more familiar with R
than GRASS, and the GRASS documentation is not as comprehensible as
that for R -- This is just because of my own bias and does not reflect
on anybody but me. I would love to try it in GRASS but I think I need
a tutorial. Any help would be greatly appreciated with this.
Stephen
On Fri, Feb 5, 2010 at 6:36 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
topmodel runs.
Stephen,
I am aware of r.topmodel in GRASS, but I am much more familiar with R than
GRASS, and the GRASS documentation is not as comprehensible as that for R
-- This is just because of my own bias and does not reflect on anybody but
me. I would love to try it in GRASS but I think I need a tutorial. Any
Stephen,
Well, don't look to me for that tutorial. I need to explore it myself for
my current project.
topmodel runs.
Stephen,
I'm not sure this is entirely correct. v.in.region saves the current *computational* region to a vector, not the area zoomed to. Setting the desired region first with g.region, I think, is the correct way to go. Then r.mapcalc can create a new raster, limited to the new smaller region.
There is probably a more eloquent way, but I have taken a vector watershed boundary, converted to a raster, and set as mask. Then used a r.mapcalc expression like "newMap=oldMap+0".
Mark
topmodel runs.
Stephen,
