[GRASS-user] Raster maps not found
Hi there,
I’ve just moved a lot of data that we’re working on onto a NAS server so that two computers could chew up the same data simultaneously. After moving everything onto the server, I copied the relevant data to the local hard drive of the computer that should be doing the analysis. On the other computer it seems to work fine, although the data was originally produced on that computer so perhaps that’s part of the problem. Anyway, when I try to start r.sun for example on the other computer, GRASS complains that it can’t find the data. The error says:
Unable to find ‘/home/lee/Documents/GRASS_Data/Hayward/StudyAreaTopography/cell_misc/horizon_143/f_format’
Unable to open raster map horizon143@StudyAreaTopography
It repeats that message for every single raster I try to call up.
I’m also not able to display any rasters. I know that they exist on the other computer and I can view them, but when I try to do that on the second computer GRASS doesn’t complain about loading them and displaying them… But absolutely nothing happens.
Any idea why this is going on? I copied the stuff straight over without modifying it in any way.
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee@isi-solutions.org
Web: http://www.isi-solutions.org
Daniel Lee wrote:
I've just moved a lot of data that we're working on onto a NAS server so
that computer so perhaps that's part of the problem. Anyway, when I try to
start r.sun for example on the other computer, GRASS complains that it can't
Unable to find
'/home/lee/Documents/GRASS_Data/Hayward/StudyAreaTopography/cell_misc/horizon_143/f_format'
Does that file exist? Is it readable by the user running GRASS?
Copying the stuff "straight over" doesn't mean that it doesn't get
modified. Particularly if you're using a FAT/NTFS-based NAS with a
Unix system, as filename case and/or permissions may be lost in the
copy.
