[GRASS-user] raster MASKs; was [GRASS-dev] interferring ovewrite flags
Michael Barton wrote:
How can you make a mask additive with r.mapcalc? This could be useful
sometime.
"additive" in a processing sense, not mathematical. (still 0|NULL,1)
for example: (spearfish)
r.mapcalc MASK='if(isnull(roads))'
r.mapcalc MASK=fields
d.rast elevation.dem
shows elevation where there is fields but no roads, as fields is read
in with a mask in place.
Hamish
Right. I understand, even if I didn't phrase it that way. Does this happen
for any r.mapcalc processing using the same procedures or just ones in which
MASK is the result? Also, is it always an "and" or can you also get the
effects of an "or"? Definitely a 'gotcha' to watch out for. I'm concerned
especially because we are doing a lot of iterative r.mapcalc processing in
scripts and this could be a problem.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 2 Oct 2006 17:18:18 +1300
To: Michael Barton <michael.barton@asu.edu>
Cc: grass list <grassuser@grass.itc.it>
Subject: raster MASKs; was [GRASS-dev] interferring ovewrite flags
sometime.
Hamish
happen for any r.mapcalc processing using the same procedures or just
ones in which MASK is the result? Also, is it always an "and" or can
you also get the effects of an "or"? Definitely a 'gotcha' to watch
out for. I'm concerned especially because we are doing a lot of
iterative r.mapcalc processing in scripts and this could be a problem.
The MASK is generally applied when a row of input data is read from the
disk.
A module scan specifically ask to ignore the MASK, but the vast vast
majority of raster modules process data by row (to save memory), and use
G_get_raster_row() to do that.
G_get_raster_row_nomask() is the non-masking version. Things that use it:
  display/d.rast.edit/mk_tmp_file.c
  imagery/i.rectify/perform.c
  imagery/i.ortho.photo/photo.rectify/perform.c
  raster/r.compress/main.c
  raster/r.le/r.le.patch/driver.c
  raster/r.le/r.le.patch/trace.c
  raster/r.le/r.le.pixel/cellclip.c
  raster/r.le/r.le.pixel/driver.c
* raster/r.null/null.c
So:
d.rast elevation.dem # displays with holes
r.mapcalc one=1 # full coverage once MASK is removed
r.mapcalc two=elevation.dem # holes once MASK is removed
g.remove MASK
d.rast one
d.rast two
the numeric mapcalc cmd hasn't read a map from the disk, so in fact it
is a solid block. The "two" map has read, so in fact contains holes.
If the "one" map is displayed with a MASK in place, it appears to have
holes in it, but these are introduced when d.rast loads the map to
display it.
clear?
Hamish
OK. Thanks. It took a bit of re-reading this to get it all--and to connect
the dots with your initial post. I think the r.mask script does not have
these issues because it uses r.reclass (like the original GRASS 5 r.mask
did), but it is a good reason for caution when using r.mapcalc to create a
MASK. Just to make sure I've got it, could you check my comments below?
Thanks
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 2 Oct 2006 20:37:36 +1300
Cc: <grassuser@grass.itc.it>
Subject: Re: raster MASKs; was [GRASS-dev] interferring ovewrite flags
disk.
These commands do NOT respect a MASK ???
So:
g.remove MASK
d.rast one
d.rast two
r.mapcalc will respect a MASK ONLY if the formula to create a new map
includes an existing map (i.e., read from disk).
A new map created from a formula that does NOT include an existing map will
NOT respect a MASK, even though it may APPEAR to do so when you display it
using d.rast with a MASK in place--because d.rast DOES respect a MASK.
display it.
clear?
I think so.
...From earlier message
MASK created with holes for roads
r.mapcalc reads map "fields", respecting MASK that leaves holes for roads,
and writes new MASK with fields but without roads.
d.rast respects new MASK that is limited to fields without roads.
It depends.
E.g. r.compress and r.null simply ignore the mask (i.e. they read the
map using G_get_raster_row_nomask()). This makes sense, as these are
low-level utilities which operate directly upon the map, rather than a
"view" of it. Similarly, both of those modules set the region to the
map's region, ignoring the current region.
OTOH, r.le.patch/driver.c seems to handle the mask itself. The actual
map is read with G_get_raster_row(), but it also reads the MASK map
directly (using G_get_raster_row_nomask(); reading MASK with
G_get_raster_row() wouldn't make much sense).
i.ifft does something similar. i.ifft doesn't read any maps, it reads
the "raw" copy which i.fft creates. Not being a map, the mask doesn't
apply, so i.ifft applies the mask itself.
> g.remove MASK
> d.rast one
> d.rast two
That's true of all modules. The mask is applied automatically to input
maps by libgis (unless the map is read using the _nomask versions of
the intput functions). It won't affect anything else unless the module
handles it explicitly (which very few do).
Yes. Anything which doesn't actually read a map will be unaffected by
the mask.
Also, note that if you use the neighbourhood modifier, e.g.:
  r.mapcalc 'out = in[10,10]'
the mask will be applied upon input, before the shift is applied.
Similarly, modules which switch regions between input and output (e.g.
r.resamp.interp, r.resamp.stats) will apply the mask at the input
resolution, not the output resolution. One consequence of this is that
r.resamp.stats may produce non-null cells where most other modules
would produce null cells due to the mask.
