Following up, why are there differences between GDAL and GRASS GIS in
the following example?
This ftp://ftp.soilgrids.org/data/aggregated/5km/OCDENS_M_sl1_5km_ll.tif
raster map, subject to `gdalinfo`:
gdalinfo OCDENS_M_sl1_5km_ll.tif -nogcp -nomd -norat -noct -nofl
Driver: GTiff/GeoTIFF
Files: OCDENS_M_sl1_5km_ll.tif
Size is 7200, 2987
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,87.370000000000005)
Pixel Size = (0.050000000000000,-0.050000000000000)
Corner Coordinates:
Upper Left (-180.0000000, 87.3700000) (180d 0' 0.00"W, 87d22'12.00"N)
Lower Left (-180.0000000, -61.9800000) (180d 0' 0.00"W, 61d58'48.00"S)
Upper Right ( 180.0000000, 87.3700000) (180d 0' 0.00"E, 87d22'12.00"N)
Lower Right ( 180.0000000, -61.9800000) (180d 0' 0.00"E, 61d58'48.00"S)
Center ( 0.0000000, 12.6950000) ( 0d 0' 0.00"E, 12d41'42.00"N)
Band 1 Block=7200x1 Type=Int16, ColorInterp=Gray
NoData Value=-32768
and GRASS GIS
# create a new Location
grass -c OCDENS_M_sl1_5km_ll.tif /geoyeux/grassdb/global/soil_grids/
# projection info
g.proj -g
name=WGS 84
datum=wgs84
ellps=wgs84
proj=ll
no_defs=defined
epsg=4326
unit=degree
units=degrees
meters=1.0
# raster info
r.info -g OCDENS_M_sl1_5km_ll
north=87.37
south=-61.98
east=180
west=-180
nsres=0.05
ewres=0.05
rows=2987
cols=7200
cells=21506400
datatype=CELL
ncats=0
# report non-NULL cells and their x, y grid location
r.stats OCDENS_M_sl1_5km_ll -n -x > stats_x
Comparing a few single pixels via:
while read LINE;do
set -- $LINE
echo " ($1,$2)
echo "GDAL: $(gdallocationinfo -valonly OCDENS_M_sl1_5km_ll.tif $1 $2)"
echo "GRASS: $3"
echo
done < stats_x_head
gives
(2930,77)
GDAL: 2090
GRASS: 2096
(2931,77)
GDAL: 2055
GRASS: 2090
(2932,77)
GDAL: 2063
GRASS: 2055
(2933,77)
GDAL: 2093
GRASS: 2063
(2934,77)
GDAL: 2240
GRASS: 2093
(2935,77)
GDAL: 2332
GRASS: 2240
(2936,77)
GDAL: 2296
GRASS: 2332
(2937,77)
GDAL: 2253
GRASS: 2296
(2938,77)
GDAL: 2179
GRASS: 2253
(2939,77)
GDAL: 2115
GRASS: 2179
Why these differences?
Nikos
# meta
GRASS 7.7.svn (2019)
libgis Revision: 74118
libgis Date: 2019-02-21 10:38:28 +0100 (Thu, 21 Feb 2019)
GDAL 2.3.1, released 2018/06/22
