I have contour maps converted to rasters (rock temperatures) in different depths (-500, -1000, -1500, -2000, -2500, -3000, -4000, -6000 meters below sea level). What is the best way to interpolate them to one 3d raster (volume)?
3d raster (volume)?
for evenly spaced raster slices first set the 3D region, e.g.
g.region t=-500 b=-6000 tbres=500
then use the r.to.rast3 module to make the 3D raster volume map.
but you would need to interpolate intermediate levels for missing slices.
For -3500 you could use r.series method=average, for 4500,5000,5500 you would
have to use r.mapcalc manually.
v.vol.rst could be used to interpolate from 3D points, but RST+contour lines
usually is prone to artifact problems do to the uneven spatial distribution of
data points.
____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage. http://www.yahoo.com/r/hs
