I’m currently working
multi-temporal LISS imagery
and I intent to make a raster stack
with 10 raster files to test a method.
With GRASS, I know that is possible to make a
stack with 3 rasters, but it’s possible
to do it with more than 3?
On Sun, Apr 4, 2010 at 4:39 PM, joel dinis <dinis.joel@gmail.com> wrote:
Hello to all,
I'm currently working
stack with 3 rasters, but it's possible
For example, both the hard and soft limits are typically 1024.
The soft limit can be changed with e.g. "ulimit -n 1500" but
not higher than the hard limit. If it is too low, you can as
superuser add an entry in
This would raise the hard limit to 1500 file. Be warned that
more files open need more RAM.
I used this to open the 1460 daily MODIS LST maps of one
year in one step in r.series.
> Hello to all,
