I have a bunch of png format images to import. I also have a csv of the images' bounding boxes.
Rather than working by hand, which would be slow - is there any quick way to turn the bounding boxes into a POINTS file for each image, to automate the georectification?
Richard
I would say you have at least 3 way to do that:
- use your bounding box points to make a vrt raster for each of your png files
- use gdalwarp to georectify your png files
- “manually” write the POINTS files to use with i.rectify (try first to georectify 1 file by hand with the “georectify tool”, and then go to the group/subgroup directories to study the files structure)
for each of those solutions you will need to write a small script to automate the process for all of your files
cheers,
Sylvain
2012/8/13 Richard Chirgwin <rchirgwin@ozemail.com.au>
I have a bunch of png format images to import. I also have a csv of the images’ bounding boxes.
Richard
grass-user mailing list
grass-user@lists.osgeo.org
