Thank you for your message. But I don't think it helps me.
I want to add a bridge elevation to my DEM. So if I create a 3d vector line (my bridge) with two vertex at x,y,z coordinates, and is it possible to convert in a raster where each cells crossed by the line inherits of his extrapolated altitude ? If no module exists to do that, what would be the operations necessary to achieve this result ? I hope it is clearer.
Frank
Le 07/04/2023 à 10:16, Helmut Kudrnovsky a écrit :
Is there a way to rasterize a 3d line to get altitude on raster cells
crossed by the line ?
- if necessary add vertice along your 3d lines (v.split ?) so their
"density" is roughly equivalent to (or better smaller than) your target
raster resolution ;
- turn your vector lines to points using v.to.points (with use=vertex
argument) ;
- convert this vector point map to a raster with v.to.rast (with use=z
argument) ;
- depending on what you do afterwards with that map, you can have a
look at r.null to manage null raster cells (e.g. setnull=0).
Hope this helps,
V.
Le vendredi 07 avril 2023 à 12:45 +0200, Frank David a écrit :
Hello,
vector
that,
hope
it is clearer.
Could you use the line to select the raster dem cells, then use the center of the selected cells to snap back to your line and use these snap coordinates to proportion the zvalue of the snapped line segment?
HTH
Zoltan
Sent from Blue
On 07 Apr 2023, at 14:47, Vincent Bain <bain@toraval.fr> wrote:
Hi Franck,
I would suggest you to do sth as follows :
raster resolution ;
- turn your vector lines to points using [v.to](http://v.to).points (with use=vertex
argument) ;
- convert this vector point map to a raster with [v.to](http://v.to).rast (with use=z
argument) ;
Hope this helps,
V.
> Hello,
> vector
> that,
> hope
> it is clearer.
> Frank
> > > cells
> > not quite sure what are you trying to do?
> > maybe:
> > v.drape:
> > Converts 2D vector features to 3D by sampling of elevation raster
> > map. ([https://grass.osgeo.org/grass82/manuals/v.drape.html](https://grass.osgeo.org/grass82/manuals/v.drape.html))
> > Additional vertices can be added to the input 2D vector map with
> > v.split.
> > or the something like:
> > v.fixed.segmentpoints - segment points along a vector line with
> > fixed distances
> > ([https://grass.osgeo.org/grass82/manuals/addons/v.fixed.segmentpoints.html](https://grass.osgeo.org/grass82/manuals/addons/v.fixed.segmentpoints.html)
> > ) followed by
> > v.what.rast - Uploads raster values at positions of vector points
> > to the table
> > ([https://grass.osgeo.org/grass82/manuals/v.what.rast.html](https://grass.osgeo.org/grass82/manuals/v.what.rast.html)) or
> > v.sample - Samples a raster map at vector point locations
> > ([https://grass.osgeo.org/grass82/manuals/v.sample.html](https://grass.osgeo.org/grass82/manuals/v.sample.html)).
> > kind regards
> > helmut
> grass-user mailing list
> grass-user@lists.osgeo.org
> [https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Hi Franck,
raster resolution ;
argument) ;
argument) ;
Hope this helps,
V.
Hello,
vector
that,
hope
it is clearer.
Frank
cells
maybe:
v.drape:
v.split.
fixed distances
) followed by
to the table
kind regards
helmut
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
