[GRASS-user] Re: Building topologically correct stream network
Hi Stephen,
I actually am fighting against almost the same problem, so let's do it together :slight_smile:
I found that r.strahler.sh works well to delineate streams and correct topology, (I use a treshold of 1km^2, it works well but don't ask me why :slight_smile: ), but (in my little experience) does not work to order streams, so I must run v.strahler after r.strahler.sh.
I know it's a very small hint but hope this helps.
Best
margherita
I have a low relief area in the costal plain of georgia that I am trying to produce a topologically correct stream network. There are many breaks in the flow accumulation grid and I would like to delineate the streams and "correct" the topology after r.thin and r.to.vect have been preformed so that I can then use v.strahler to order the streams. Thanks for any help and I will provide and data that would be helpful. thanks,
-- Stephen Sefick Let's not spend our time and resources thinking about things that are so little or so large that all they really do for us is puff us up and make us feel like gods. We are mammals, and have not exhausted the annoying little problems of being mammals. -K. Mullis
Eng. Margherita Di Leo
Ph.D. Student Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
Office: +39-0971205363
Fax: +39-0971205160
E-mail: dileomargherita AT gmail DOT com
Skype: dileomargherita
URL: http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
Hi
maybe this will help:
http://gis.vsb.cz/GIS_Ostrava/GIS_Ova_2009/sbornik/Lists/Papers/060.pdf
it require another gis program but gives great results!
Jarek
Margherita Di Leo pisze:
Hi Stephen,
Best
margherita
I'm sorry but the procedure that I proposed does not produce good results. In fact the ascii file produced by v.strahler has very strange orders, and also many 0 (that does not have sense in strahler order!). I think the problem is generated in finding the outlets and/or confluences.
Waiting for the response of the List (please)..
margherita
Jarek Jasiewicz wrote:
Hi
Jarek
Hi Stephen,
Best
margherita
Fax: +39-0971205160
Hi Jarek
Hi
What were the limitations of the GRASS raster-to-vector conversion tools you encountered? It's not clear to me from Fig. 3, but I would like to understand the problem, and I hope you can explain it in a bit more detail.
Thanks a lot,
Markus M
Outlet points are where stream is not null and drainage direction is negative, e.g.
r.mapcalc "outlet_points = if(!isnull(streams) && drainage < 0, streams, null())"
That would give you outlet points whose cell value is the stream segment number leading to the outlet point.
and/or confluences.
All nodes of the stream vector, excluding outlet points?
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
Well, I am not sure what I am going to do. I would look at the code,
but I am not adept at C. Also, I don't know if I understand the
algorithm, but I think if the topology were complete then it would
work OK. I think the 0 orders are unconnected streams- danglers.
This makes sense because they are neither a tributary nor a main stem.
The topology is the problem, and I can't figure out how to correct
this.
thanks
Stephen Sefick
On Tue, Jul 21, 2009 at 12:34 PM, Markus
negative, e.g.
null())"
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
                -K. Mullis
Markus Metz pisze:
Hi Jarek
Hi
that problems are shown on fig 4)
1) streams directions are not correct (are random) because we have no information about its directions in raster file
2) there are problems if streamlines toutch each other like
In fact I use script to convert Terrain Analysis System data to Grass topological data. I attached it here (note it is not GRASS script with full error handling). Sorry for polish comment but I have not time to translate it. If you need more information how it works contact me off list.
Jarek
BTW I'm about to finish regular grass modue for calculating Strahler Stream order and Shreeve Stream Magnitude. I hope I publish it for testing in next few days. Any help appreciated.
Thanks a lot,
Markus M
(attachments)
strahler (5.21 KB)
Jarek Jasiewicz pisze:
Markus Metz pisze:
Hi Jarek
Hi
Opps... there is the problem in the paper: fig 3 shoud be fig 4 and fig 4 shoud be 3 sorry ....
Jarek
I would be happy to help test!
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
I just don't know how. Tell me what to do - I am new to grass, and I
am a intermediate in compiling software. Also, I am running mac os x
if that makes a difference, and I can also test on a debian ppc linux
laptop.
thanks
Stephen Sefick
On Tue, Jul 21, 2009 at 2:32 PM, Dylan Beaudette<debeaudette@ucdavis.edu> wrote:
Dylan
Dylan Beaudette
530.754.7341
Stephen Sefick
                -K. Mullis
Should not happen unless you specified real depressions in r.watershed. How did you extract streams?
What exactly is wrong with topology? The existence of these dangles?
Markus M
this.
thanks
Stephen Sefick
negative, e.g.
null())"
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
re: inline
On Wed, Jul 22, 2009 at 2:01 AM, Markus
flow accumulation from r.watershed -> multiplied by gridcell area and
multiplied by average runoff for that hydrologic unit code in map
calc-> r.thin -> r.to.vect
Maybe there is nothing wrong. On further reflection the area that I
am trying to use this procedure on is very flat and there are
intermittent streams and wetlands (site visit) all over the study
area. These non-connected lines maybe showing intermittentancy?
Markus M
this.
thanks
Stephen Sefick
results.
and
negative, e.g.
null())"
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
why :slight_smile:
must
Best
margherita
trying
breaks in
and
so
help and
about
is puff
exhausted the
Stephen Sefick
                -K. Mullis
code, but I am not adept at C.
none the less, it doesn't hurt to look, depending on how it is written
it might be understandable / tweakable.
MMetz:
note the v.strahler help page makes special mention that if you used
r.watershed you should check the topology. Maybe it makes a bitter deal
out of that than is really the case?
S:
I am trying to use this procedure on is very flat and there are
study area. These non-connected lines maybe showing
intermittentancy?
do you see a "ladder effect" in the r.to.vect river network?
(like a braided river with all joins at right angles)
maybe that is the problematic topology the module is concerned about?
Hamish
Hamish wrote:
MMetz:
S:
intermittentancy?
I can only think of these two possible problems - dangles and ladders. Dangles are caused by the method used to extract streams from a flow accumulation map whereas these ladders are an artefact of r.to.vect.
I'm regularly trying out different threshold values in r.watershed, only to get different streams to be vectorized, flow accumulation and drainage direction are not affected by the threshold option in r.watershed. I have an idea for a new module that would take flow accumulation and theshold as input and would then extract streams from it, both as raster and as vector (topologically clean in the v.strahler sense). This new module would work with both SFD and MFD flow accumulation and with r.terraflow flow accumulation. The problem is that the rough concept exists in my head only and I have no time right now to develop this module. All the code is there in r.watershed, it just needs to be reorganized a bit...
Markus M
Hi all
Hi Markus,
thanks for your answer. I found that the problem is in the topology of the river network. I think that v.strahler produces many '0' because it finds many little 'circles' in the stream vector. I tried to produce the stream network both with r.watershed -> r.to.vect and with r.strahler.sh -> r.to.vect: the results obtained in both ways are very similar. Is there a way to eliminate these circles, not by hand ?
Thank you for your time
margherita
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
Fax: +39-0971205160
Dylan
+1
cheers
margherita
Fax: +39-0971205160
Hi..
If I well remember, the problems of 0 values in the category data were
related to braiding or similar artifacts deriving from rasterization
process
r.strahler used with threshold not too small should clean network and
solve the task...
here [1] (in italian.. sorry...) you can find some pictures about this
topic...
sorry but it was more than one year ago and I don't remember well all
these problems..
[1]
http://www.grassmeeting2008.unipg.it/interventi/Cencetti_et_al_licensed.pdf
MMetz:
S:
> intermittentancy?
Hamish
Hi all
Hi Markus,
r.strahler.sh tries to if I understand the script right, but there must be side effects: what were parallel streams with a ladder may be merged into one stream.
Maybe a new module to extract both raster and vector stream networks from any flow accumulation map would indeed be useful.
Markus M
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
Markus I believe that would be invaluable. I will help in anyway that I can.
Stephen Sefick
On Thu, Jul 23, 2009 at 9:25 AM, Markus
Hi all
Hi Markus,
one stream.
Markus M
negative, e.g.
null())"
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
Stephen Sefick
                -K. Mullis
Markus Metz pisze:
Hi all
Hi Markus,
Yes, r.to.vect will almost never give correct directional network. It require, as Marcus pointed different approach. r.flow ma be a good starting point to create new module
Jarek
Markus M
and/or confluences.
Markus M
margherita
Hi
Jarek
Hi Stephen,
Best
margherita
