On Sat, 07 Nov 2009 15:44:09 -0600,
Seb <spluque@gmail.com> wrote:
On Sat, 07 Nov 2009 00:10:28 -0700,
Kevin Rodgers <kevin.d.rodgers@gmail.com> wrote:
How about:
(let ((comint-input-ring-file-name "/path/to/local/.bash_history"))
(shell))
Thanks for the explanation Kevin. There is no difference with your
suggestion, however. In the resulting shell buffer I see:
,-----[ C-h v comint-input-ring-file-name RET ]
comint-input-ring-file-name's value is "~/.bash_history" Local in
buffer *shell*; global value is nilDocumentation: If non-nil, name of the file to read/write input
history. See also `comint-read-input-ring' and
`comint-write-input-ring'.This variable is buffer-local, and is a good thing to set in mode
hooks.You can customize this variable.
[back]
and cycling shows that: i.e. "M-n" and "M-p" cycle through
~/bash_history, rather than the value in the `let' statement. This is
strange. This is on Emacs 23.
I eventually solved this with:
(defun grass (full-location)
"Call grass with FULL-LOCATION arguments and set up a shell buffer
to work on. FULL-LOCATION must be a fully-qualified GRASS location;
i.e. it must include GISDBASE/LOCATION_NAME/MAPSET.
The GRASS process runs in a shell buffer, named *GRASS*."
(interactive "DLocation: ")
(let ((grassbuf "*GRASS*"))
(shell grassbuf)
(comint-send-string grassbuf (concat "grass " full-location "\n"))
(setq comint-input-ring-file-name
(or (getenv "HISTFILE")
(concat (directory-file-name full-location)
"/.bash_history")))
(comint-read-input-ring)))
Cc'ing the grass-user list where it might be of interest.
Seb
