Hi to all,
I think I can install GRASS already. At the end, I receive a note like:
│ Operating System Distributor License for Java v1.1 (DLJ) ↑
│ Operating System Distributor License for Java version 1.1 (DLJ) ▒
│ SUN MICROSYSTEMS, INC. ("SUN") IS WILLING TO LICENSE THE JAVA PLATFORM ▒
│ STANDARD EDITION DEVELOPER KIT ("JDK" - THE "SOFTWARE") TO YOU ONLY UPON ▒
│ THE CONDITION THAT YOU ACCEPT ALL OF THE TERMS CONTAINED IN THIS LICENSE ▒
│ AGREEMENT (THE "AGREEMENT"). PLEASE READ THE AGREEMENT CAREFULLY. BY ▒
│ INSTALLING, USING, OR DISTRIBUTING THIS SOFTWARE, YOU ACCEPT ALL OF THE ▒
│ TERMS OF THE AGREEMENT.
However, I have no idea where it is installed and how to launch GRASS?! Could you please send any help?
Best regards,
Tri Van
This message was sent using IMP, the Internet Messaging Program.
On Mon, 2008-10-20 at 00:40 +0700, Van PD Tri wrote:
Hi to all,
Best regards,
Tri Van
Hi!
I don't think(=know if) that the "Java" message has anything to do with
GRASS.
(a) You can launch grass from a terminal by typing:
gass -gui
(b) Or you want to add a new menu item (Ubuntu specific: System >
Preferences > Main Menu > New Item -- then enter "grass -gui" withouth
the qiuotes in the "command" field, give some a name for your new
"launcher" and a description if you like. *** Decide under which Menu
you want/will place the "grass" launcher ***).
You might (...probably) want to read the following thread(s):
http://www.nabble.com/grass-gis-td19636258.html
http://www.nabble.com/grass-gis.-td19636354.html
Kind regards, Nikos
Hi to all,
Thanks Nikos!
I have just practised your guidance (i.e. > (a) You can launch grass from a terminal by typing: grass -gui)
After doing it, the following error appear:
dtat@dtat-desktop:~$ grass -gui
The program 'grass' is currently not installed. You can install it by typing:
sudo apt-get install grass
bash: grass: command not found
I wonder why because I did run the command
And it looks like I was doing successful.
Could you please give me further help.
Best regards,
Tri Van
Quoting Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Hi to all,
Best regards,
Tri Van
Hi!
GRASS.
gass -gui
Kind regards, Nikos
Hi!
(Assuming you work with Ubuntu Hardy Heron 8.04)
I would remove everything related with grass and re-install again (using
Jachym's repository [1]). Open a terminal and...
1. execute the following command:
sudo apt-get purge grass
2. According to [1] edit the sources.list file which is under /etc/apt:
sudo gedit /etc/apt/sources.list
3. Add the 2 lines in the end of the file for example (although you can
add them anywhere else) as procided in [1]:
deb http://les-ejk.cz/ubuntu hardy multiverse
deb-src http://les-ejk.cz/ubuntu hardy multiverse
4. Save and close the sources.list file
5. Get Jachym's gpg signature
wget -q http://les-ejk.cz/pgp/jachym_cepicky-gpg.pub -O - | sudo apt-key
add -
6. Update and Upgrade
sudo apt-get update && sudo apt-get upgrade
7. install grass with:
8. Launch grass with:
grass -gui
Good Luck, Nikos
[1] http://www.les-ejk.cz/ubuntu/
