[GRASS-user] Re: dbf File not being Created with v.in.ascii
Ryan,
OK, so there are no attributes in the CSV but only geometry and
category number (ID). GRASS will not create a DBF file
since there is no need for it, given these data.
If you want to later add a table, simply use v.db.addtable.
Hope this helps,
On Tue, Jul 24, 2007 at 10:42:26PM -0700, ucl wrote:
Perhaps I am misunderstanding what you mean by defining attribute columns.
Here are the first two lines:
Latitude,Longitude,Category
34.420757,-119.685126,1
Markus Neteler wrote:
> Can you post the first two lines of you CSV file? Otherwise the problem
> is hard to understand. So far you still don't define any attribute
> columns,
> hence, no DBF (or other table) is generated.
> Markus
> Ryan Rosario wrote on 07/24/2007 09:26 AM:
>> Thanks for the suggestions.
>> I tried that and it did not work. I added an extra column to my data
>> file called category and exported it to CSV. I then read in the vector
>> using
>> v.in.ascii input='responseTime.csv ' output=response format=point
>> fs=',' skip=1 col='y double, x double, cat int' x=2 y=1 cat=3 --overwrite
>> I did this both in the GUI and command-line and I also deleted the
>> previous vector in case there was garbage left over.
>> v.info response shows no dblinks.
>> Is there something else I can try?
>> Ryan
http://www.nabble.com/dbf-File-not-being-Created-with-v.in.ascii-tf4127648.html#a11759207
