[GRASS-user] Re: EPSG code for KML (micha@arava.co.il)
FWIW, I've been teaching a workshop on basic GPS + GIS for archaeology in China, using QGIS.
For the Mac at least, the QGIS GPS tools don't work--or don't work correctly. I've got the latest and greatest GPSBabel and QGIS 1.4. The QGIS GPS plugin cannot find GPSBabel. It seems this is because it is assuming that it is set up like on Linux instead of like on the Mac.
Michael
____________________
C. Michael Barton
Arizona State University
Date: Mon, 12 Jul 2010 16:20:22 +0300
Subject: Re: [GRASS-user] EPSG code for KML
To: "Bulent Arikan" <bulent.arikan@gmail.com>
Cc: grass-user@lists.osgeo.org
Message-ID:
        <39b431e3aa73dab567afde4e1465855e.squirrel@webmail.arava.co.il>
Content-Type: text/plain;charset=windows-1255
On Sat, Jul 10, 2010 at 6:33 PM, Hamish <hamish_b@yahoo.com> wrote:
Bulent wrote:
> I occasionally use Google Earth ?GE? (kml files) and I am aware of the
> fact that there is a bit of distortion (i.e., metric offset) between
GE
> and other projections for a variety of reasons. I am wondering if
anyone
> knows whether there is an EPSG code for KML format so that I can
create
> a LOCATION in Grass using this code and avoid/minimize such
distortions
> when I import vector files.
It is fundamentally broken, do not use it for serious GIS work. It is
only valid for visual use and saving cpu cycles on large deployments.
(which is both acceptable and very important for folks like google)
(epsg initially refused to include it but finally caved to mass user
pressure)
but if you do want to use it, it's just the mercator projection with
a spherical ellipsoid using the WGS84's ellipsoid's major Earth radius
as the only sphere radius. quite simple to define.
Hamish
I was wondering about this. I read several online articles about the
problems and the doubts that EPSG has. Unfortunately, I was planning to
use
this for my archaeological work, which requires accuracy such as locating
the trenches and the features, like walls. My issue is, when I need to
show
polygons (e.g., a rectangle representing a trench), I transfer my GPS
points
(the readings at 4 corners) to GE and create a polygon there, save it as
KML. Then, I open this in QGIS, make a shape file there and import it into
GRASS. I suspect there is some distortion and this is a far too
complicated
routine but I do not know a more practical way.
I'm curious: Did you try the GPS Tools plugin in QGIS?
You can simply import the waypoints. They will be in Lon/Lat WGS84,
avoiding any of the problems with GE projections. THen, in QGIS make your
polygons, and when you save as shapefile, choose any CRS you want for
re-projection. Thus your original GPS points, and the polygons will always
be in Lon/Lat geographic CRS. And for mapping/measuring you can choose any
appropriate CRS.
' v.in.gpsbabel ' works fine for retrieving points and tracks from my
device. Alternatively, I may digitize the points to create polygons after
they are imported in GRASS. I still have to try ' v.in.ascii '
B&#65533;ENT
This mail was received via Mail-SeCure System.
grass-user mailing list
End of grass-user Digest, Vol 51, Issue 25
Hi Michael,
If you create a link to the binary inside the OS X gpsbabel application, you should be ok. You can do this, assuming you have the latest gpsbabel binary install in your Applications folder, with this command from the Terminal:
sudo ln -s /Applications/GPSBabelFE.app/Contents/MacOS/gpsbabel /usr/local/bin/gpsbabel
Alternatively, you can add the path to your Bash profile.
Hope that helps,
John
Michael
C. Michael Barton
Message-ID:
GE
anyone
create
distortions
pressure)
Hamish
use
show
points
complicated
appropriate CRS.
B&#65533;ENT
Thanks. I'm just now back and will try this out soon.
Michael
C. Michael Barton
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jul 15, 2010, at 12:29 PM, John C. Tull wrote:
Hi Michael,
Hope that helps,
John
Michael
C. Michael Barton
Message-ID:
GE
anyone
create
distortions
pressure)
Hamish
use
show
points
complicated
appropriate CRS.
B&#65533;ENT
