[GRASS-user] Re: "Error setting region" on Grass startup (Hamish)
Hi Hamish
I have attached the information asked for below. The region is pretty much as I entered it. It is just a test, so I know the resolution is too low for real work. I had some finger trouble with the datum, but it seems to have defaulted to WGS84, which is right.
I see I have two different versions of libgdal installed. Should I uninstall the additional libgdal with “sudo apt-get uninstall …”? And should gdal-bin and libgdal1-dev be uninstalled as well?
Thanks
Brendon
Message: 2
Date: Sat, 15 Nov 2008 22:28:31 -0800 (PST)
Subject: Re: [GRASS-user] “Error setting region” on Grass startup
brendon wolff-piggott wrote:
I have installed Grass 6.3 on Ubuntu 8.04 from deb
http://les-ejk.cz/ubuntu/ hardy multiverse. Every time I
start Grass and select a location and mapset I get “error setting
region” and “child process exited abnormally”.
From googling around this seems to have to do with Gdal not being
installed. So I did “sudo apt-get install gdal-bin”, based on
http://www.perrygeo.net/wordpress/?p=119.
right.
I still have the same problem in Grass and no plain gdal
executable in usr/bin (gdalinfo, gdal_translate, gdalwarp etc).
Just to make this clear - I have all the utilities in brackets
what does “g.region -p” from the GRASS terminal prompt say?
GRASS 6.3.0 (Geographic_WGS84):/usr/bin > g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: wgs84
north: 22:07:30.108S
south: 34:50:03.012S
west: 16:27:06.804E
east: 32:56:41.928E
nsres: 0:38:07.6452
ewres: 0:49:28.7562
rows: 20
cols: 20
cells: 400
what does “dpkg -l | grep gdal” say?
GRASS 6.3.0 (Geographic_WGS84):/usr/bin > dpkg -l | grep gdal
ii gdal-bin 1.5.1-3 Geospatial Data Abstraction Library - Utilit
ii libgdal1-1.4.0 1.4.4-1ubuntu3 Geospatial Data Abstraction Library
ii libgdal1-1.4.0-grass 1.4.4-1 GRASS extension for the Geospatial Data Abst
ii libgdal1-1.5.0 1.5.1-3 Geospatial Data Abstraction Library
ii libgdal1-dev 1.5.1-3 Geospatial Data Abstraction Library - Develo
Should I uninstall Grass and reinstall, or do I need
another version of gdal??
You need the version of GDAL that your grass binaries were built with/for.
you can tell that with ldd, try this from the GRASS terminal prompt:
ldd $GISBASE/lib/libgrass_vect.so | grep gdal
GRASS 6.3.0 (Geographic_WGS84):/usr/bin > ldd $GISBASE/lib/libgrass_vect.so | grep gdal
libgdal1.4.0.so.1 => /usr/lib/libgdal1.4.0.so.1 (0xb7a10000)
Hamish
