Message: 8
Date: Thu, 18 Feb 2010 16:53:50 -0700
Subject: [GRASS-user] graphically selecting multiple features
To: grass-user@lists.osgeo.org
Message-ID: <4B7DD30E.3030800@telus.net>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedHello, I'm new to GRASS, coming from an Arc* background, and often find that I'm approaching things from the wrong direction. I'm using GRASS 6.4 with the wxPython GUI.
I would like to graphically select multiple features from a large vector file and edit an attribute of those features. (I have a poorly classified polygon shapefile of hydrology and want to separate the rivers from the lakes). How can I go about this. With v.what.vect I seem to be able to only edit one feature at a time.
Any suggestions will be appreciated.
Kurt
Kurt,
If you're not on Windows, you could use d.extract.
d.mon x0
(starts the monitor)
d.vect <vector name>
(displays the map)
d.extract <vector name> <output name>
This will allow you to select all of the features you want using the mouse, into a new map.
For eg: you could select all the rivers into a new vector, edit the attribute in the new vector (various ways to do this in Grass, or use your DBMS to edit the feature), then set that attribute back in the original map.
Clunky, I realise, but it will be quicker than setting lots of attributes one at a time!
Richard
