[GRASS-user] Re: GRASS-6.4 error
On May 22, 2009, at 3:48 PM, Lee Eddington wrote:
I am trying to run GRASS-6.4 for Mac OS X for the first time as a GRASS user and am having the following problem.
and an error window that says "Error setting region (Problem with g.region?): child killed: trace trap". There is an "OK" button on this window, but when I click on it nothing happens.
new-host-2:~ lee$ /Library/Frameworks/GDAL.framework/Versions/1.6/Programs/gdalinfo
dyld: Library not loaded: /usr/lib/libiconv.2.dylib
Referenced from: /Library/Frameworks/GDAL.framework/Versions/1.6/Libraries/libpq.dylib
Reason: Incompatible library version: libpq.dylib requires version 7.0.0 or later, but libiconv.2.dylib provides version 5.0.0
Trace/BPT trap
So I guess I need a more current version of libpq.dylib, but I'm not sure on how to go about getting and properly installing it.
There was a problem with the GDAL 1.6.1 framework on OSX Tiger where I bundled the Leopard libpq by accident. It should be fixed in GDAL 1.6.1-3.
When GDAL has a problem, it doesn't show up when you start GRASS, only when you try to run a module.
PS. the mailing lists are a better place to ask questions - others may have a similar problem and are either too timid to ask, or don't know what to ask, or it may not be a direct problem with my binary packages. And any answers will then be available to others in the archives. (I'm cc-ing the user list)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
