Solimyr wrote:
http://packages.ubuntu.com/maverick/grass-dev
http://packages.ubuntu.com/maverick/grass-devI’ve tried to install but is not compatible!Can’t install!
Do you know where I can find the grass-dev package for my GRASS and Ubuntu
version?
From my modest experience: to install add-on normally you, in general, must install GRASS from source and then install add-on as noted on http://grass.osgeo.org/wiki/Compile_and_Install#Addons page.
Other things like “grass-dev” packages and so on – IMHO just wishes how it will be… If I’m wrong, correct me.
One more stupid thing; If I install an addons on GRASS, after that, can I
use the same on the GRASS Plugin in QGIS?
In simple way, as I know, NO. But it’s possible to add modules to GRASS Plugin in QGIS with the special method.
