It works quite nicely!!
Nice pngs, nice pdfs. takes a while to generate the pdf, file size is
a bit big, but it is good!
I like it. with some adjustments, we can have easy pdf maps!
good work!
Carlos
On 10/16/07, Lars Ahlzen <lars@ahlzen.com> wrote:
Carlos "Guâno" Grohmann wrote:
> Can you give some examples of the usage? (not the final product, but
> the commands)
> thanksSure... the usage is virtually identical to other drivers like the X or
PNG drivers.For example, you may start GRASS with everyone's favorite South Dakotan
dataset, set up the environment and start a monitor. Then use the
standard GRASS drawing commands to draw, and finally close the monitor,
which will output the result to a file.Here's a very simple example:
lars@saturn ~ $ grass63
Welcome to GRASS 6.3.cvs (2007)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
Start the graphical user interface with: gis.m
When ready to quit enter: exit
GRASS 6.3.cvs (spearfish60):~ > d.mon -l
name description
PNG Create PNG Map
png1 Create PNG Map
ps7 Create PS Map
CAIRO Create Cairo Map
cairo1 Create Cairo Map
cairo2 Create Cairo Map
cairo3 Create Cairo Map
cairo4 Create Cairo Map
cairo5 Create Cairo Map
cairo6 Create Cairo Map
cairo7 Create Cairo Map
x0 X-windows graphics display
x1 X-windows graphics display
x7 X-windows graphics display
GRASS 6.3.cvs (spearfish60):~ > export GRASS_TRUECOLOR=TRUE
GRASS 6.3.cvs (spearfish60):~ > export GRASS_CAIROFILE=spearfish.png
GRASS 6.3.cvs (spearfish60):~ > export GRASS_WIDTH=1000
GRASS 6.3.cvs (spearfish60):~ > export GRASS_HEIGHT=1000
GRASS 6.3.cvs (spearfish60):~ > d.mon start=CAIRO
CAIRO: collecting to file: spearfish.png
GRASS_WIDTH=1000, GRASS_HEIGHT=1000
Graphics driver [CAIRO] started
GRASS 6.3.cvs (spearfish60):~ > d.rast map=elevation.10m
100%
GRASS 6.3.cvs (spearfish60):~ > d.vect map=streams width=1 color=blue
GRASS 6.3.cvs (spearfish60):~ > d.vect map=roads width=2
GRASS 6.3.cvs (spearfish60):~ > d.mon stop=CAIRO
Monitor 'CAIRO' terminated
GRASS 6.3.cvs (spearfish60):~ > ls *.png
spearfish.png/ Lars
Lars Ahlzen
lars@ahlzen.com
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
