On 12/7/06, Hamish <hamish_nospam@yahoo.com> wrote:
Dylan Beaudette wrote:
> > > > Get local Linke values from the SoDa Solar radiation Databases
> > > > http://www.soda-is.com/
> > > Tried this, and got unrealistic values for my site.
> > how so? Have you calculated good Linke values from your light
> > meters? (formula for that, please?)
> Attached is a plot of estimated Linke turbidity values, compared to
> the SoDa derived data. Details on this calculation soon to follow in
> a new thread.
Hi Hamish,
Looks like I sent an update this morning with an attachment that was too large!
I'll Include it at the bottom of my replies to you last message.
I assume the physical basis for the Linke turbidity factor is the amount
of scattering dust, ash, water vapour, turbulence etc. in either the
column of air directly above the sampling site or in the ray between the
site and the Sun (which will pass through more atm in winter due to the
lower angle). Maybe the paper sheds some light on that. So e.g. LA
county would have very high turbidity numbers.
I would figure in the winter the air to be crisper/clearer due to less
water vapour, less turbulence, and less upwelling of aerosol laiden warm
air from the Earth's surface. So lower turbidity numbers in the winter
as the SoDa data shows. BUT if you live in a place which is prone to
inversion layers in winter and many locals heat their homes with wood or
coal, winter air quality may turn out to be much more turbid.
Actually have a couple good papers on the defintion for the Linke
turbidity values:
Louche, A.; Peri, G. & Iqbal, M. An analysis of linke turbidity factor
Solar Energy, 1986, 37, 393-396
Rapti, A. S. Atmospheric transparency, atmospheric turbidity and
climatic parameters Solar Energy, 2000, 69, 99-111
Kasten, F. The linke turbidity factor based on improved values of the
integral Rayleigh optical thickness Solar Energy, 1996, 56, 239-244
My site is in a mediterranean, semi-coastal / semi-arid setting where
winter time moisture and summer time dryness are the usual weather
patterns. Summer through fall are usually cloud free, and quite warm.
Also- this site is rather remote, so urban ag-related dust influences
are minimal. These are some of the reasons that I was having second
thoughts about the SoDa values.
> I have calculated Linke turbidity for my site with the equation
T_linke = ln( G / ( I_0 * sin(h) * 0.84) ) * ( sin(h) / -0.027 )
> Unfortunately, there are some aspects to this equation which
> I do not understand: namely the two constants present.
perhaps they are empirically derived?
Ok- big change in direction. I posted an update to the use of the
above equation earlier today but it was rejected due to a large
attachment. Details below....
I take it I_0 is pure-clear air intentensity?; h is latitude?; and is G
measured intensity, or ..?
G = global radiance measured on the ground (beam+diffuse)
I_o = extraterrestrial radiance
h = solar elevation (angle)
> 1. Becker, S. Caclulation of Direct Solar And Diffuse Radiation in
> Israel International Journal of Climatology, 2001, 21, 1561 - 1576
I will have to track down a copy of that. Holy cow, for once our library
is actually subscribed to the e-journal. Downloading the PDF now..
... i know how that can be sometimes!
What software did you use to make that plot? Looks nice.
Thanks. It was made in R, a fun command-line based environment for
plotting, analysis, etc. I can post the code used after a small
cleanup.
Ok, here is the text from the message rejected this morning:
Some updates on my findings with respect to obtaining optimal Linke
turbidity values via local pyranometer measurements.
Chatting with a local atmospheric scientist, I learned that it is
possible (with a loss of some precision of course) to dissaggregate
beam radiance from global radiance (as measured by pyranometer), for
use in an equation [1] for the linke turbidity factor. Compared to a
previous paper I mentioned on grass-dev [2], the equation presented in
[1] is a much more appropriate approach to calculating Linke turbidity values.
The key points to using the equation from [1] are:
- historical pyranometer data from a weather station, with coordinates!
- r.sun mode 1 to calculate solar elevation at this station, for each
day at some time. extraterrestrial radiance is also calculated in this
step
- dissagregation of the beam component from global radiance with the
assumption that diffuse radiance is approx 10%-20% that of the beam
radiance
- conversion of dissaggregated beam radiance to beam radiance on the
normal (B/sin alpha)
here is a link to a bit of my thesis on this topic: (rather incomplete!)
http://169.237.35.250/~dylan/temp/linke-cucumo2000.png
Here is a link of linke turbidity values, as calculated by the method
described above, along with a comparison to the SoDa-derived values.
There is considerable difference between the two sources!
http://169.237.35.250/~dylan/temp/cucumo-estimated_daily_linke_values.png
With the equation from [1] it is possible to estimate the linke
turbidity value for each day (using the 12pm calculation as
representative for an entire day), and use these estimates in r.sun
mode 2. here is a summary of the incorporation of estimated linke
values into r.sun - as compared to the weather station data:
http://169.237.35.250/~dylan/temp/11-yr_variation_vs_modeled.png
I'll post some updates as they come. If I have anything wrong please
don't hesitate to point it out!
Dylan
1. Cucumo, M.; Kaliakatsos, D. & Marinelli, V. A calculation method
for the estimation of the Linke turbidity factor Renewable Energy,
2000, 19, 249-258
2. Becker, S. Caclulation of Direct Solar And Diffuse Radiation in
