[GRASS-user] Re: [GRASS-dev] Grass Python question: do not print warnings
Hi MArtin
It worked
I just have one final question:
I pretend to apply your suggestion to
proj_image = grass.read_command(‘g.proj’, flags = ‘jf’, georef = src_file) to this.
If I get a piece of text in proj_image (like the geoprojection information of the src_file, will the stderr=nulldev eliminate the output of this function?
Thanks
Franz
2011/3/17 Franz Schiller <franzschiller1975@gmail.com>:
It worked
proj_image = grass.read_command('g.proj', flags = 'jf', georef = src_file)
to this.
function?
I don't fully understand your question, anyway it will discard all
messages printed by `g.proj` to stderr.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
to this.
function?
"g.proj -jf ..." writes the projection information to stdout.
grass.read_command() captures data written to the program's stdout and
returns it as a string.
Passing stderr=... will redirect messages and warnings which would
otherwise have gone to e.g. the terminal. It won't affect the passing
of the projection information to the Python script.
