[GRASS-user] Re: [GRASS-dev] r.out.gdal Gtiff output does not preserve color tables
On Feb 28, 2008, at 10:36 PM, grass-user-request@lists.osgeo.org wrote:
Date: Thu, 28 Feb 2008 20:40:36 -0800
Subject: Re: [GRASS-user] Re: [GRASS-dev] r.out.gdal Gtiff output does
To: Hamish <hamish_b@yahoo.com>
Cc: grass-user@lists.osgeo.org
Message-ID: <200802282040.36958.dylan.beaudette@gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
On Thursday 28 February 2008, Hamish wrote:
Dylan Beaudette wrote:
- r.out.gdal never worked for me (or rather the resulting file would
not open in ArcMap)
did you try adding INTERLEAVE=PIXEL and *not* using LZW compression
for createopt=?
From the help r.out.gdal page:
NOTES
When writing out GeoTIFF format for users of ESRI software or
ImageMagick, the band interleaving should be switched to pixel
interleaving using createopt="INTERLEAVE=PIXEL".
To specify multiple options use a comma separated list
(createopt="TFW=YES,COMPRESS=DEFLATE").
Hamish
Yep-- I have tried both of those options. I either get a file which will not
open (mysterious ESRI error), or the file's data range is reported as some
huge negative number <--> to some huge positive number, something like
3x10^25 . I will check on the exact value and report back.
We've also had this problem. We are using geotiffs as a standard raster format for archiving. So this is a real pain.
However, FWIW, we've also experienced the same problem that Dylan reports above in geotiffs produced by ArcGIS--a bunch of huge, meaningless numbers in the data.
So if we can fix this, we're one up on the commercial competition.
Michael
