Alle 16:48, martedì 5 dicembre 2006, Davide Spano ha scritto:
Il giorno mar, 05/12/2006 alle 14.53 +0100, Leonardo Lami ha scritto:
> Hi
> I make some tests and I send you the gpsbabel output files.
> For every type of gps (garmin 12, garmin 12xl and garmin 12 etrex) I make
> two file:
> a gpx file create from gpsbabel by "gpsbabel -w -i garmin -f /dev/ttyUSB0
> -o gpx -F *.gpx"
> a csv file create from v.in.gpsbabel using grass_write_ascii.style like
> in the script
> You can see that for "garmin 12" and "garmin 12xl" v.in.gpsbabel does not
> transfer the field "name" (present in the gpx files) in the csv files.
> Regards
> LeonardoHi all,
the data is not downloaded because in the grass_write_ascii.style I did
not put a field for that data (I believed that was only a progressive ID
for the waypoint...)
But way the field is present in the case of garmin etrex also in the
grass_write_ascii.style?
I propose to take a look at this page
http://www.gpsbabel.org/htmldoc-1.3.2/style_define.html
and tell me what fields are important to download, when we agree to the
list, I'll fix the problem in the script.
I would add only the filed called "name" in the gpx file
Have someone other ideas?
Regasrd
Leonardo
Davide
Leonardo Lami
email + jabber: lami@faunalia.it
www.faunalia.it
Cell: (+39)349-1310164 Tel+Fax: (+39) 0587-213742
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy
Leonardo Lami
www.faunalia.it
